Panasonic Tc-p50x3 50-inch Viera 720p Plasma Hdtv Logo
Anonymous Posted on Aug 17, 2013
Panasonic tc-p50x3, when turns on red light flashes 8-10x, in 3-5 series then goes off. Never any picture
Level 3:
Top Expert:
  • Panasonic Master 76,851 Answers
  • Posted on Aug 17, 2013
Panasonic Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986505
Points
237762
Count the exact number of flashes occur at one time switch ON. These are called blinking codes, and is fault indication. From the number of blinks occurs at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. If you wish to get more details about blinking codes, check this site. It has details to blinking codes with many brand TVs. http://electronicshelponline.blogspot.com/ Pull up previous posts, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option. Select view option by the drop-down view box, at the top left or the display window.
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Jul 03, 2008
SOURCE: panasonic plasma vieta
I just bought a Panasonic TH-42PZ800U and had the same problem. 10 blinks and the TV would not start. Then after some trial and error I solved the problem!
Here is my (apparent) observation and solution:
I had only one input into the TV, which was my HTPC connected via a DVI-to-HDMI cable plugged into the Panny's HDMI 1 slot. *IF* the HTPC was already on, then the Panny would have the blink of death. *BUT* if the HTPC was off, the Panny booted fine (assuming I cleared the blink of death first by powering off the HTPC, unplugging the TV, and replugging the TV back in with the HTPC still off).
My solution was to move the HDMI cable from slot 1 to slot 3. After making this one change, everything worked as it should. No more 10 blinks of death. I could even leave the HTPC on and turn on the TV last, and it still worked. Tried this 10 times, worked 10 times.
I don't know if this will solve other people's problems, but I hope it at least provides some clues. I wonder if this is a fundamental circuit design flaw on the part of Panasonic, rather than a "bad batch of parts" problem.
Thoughts? Feedback? Send to gcpien at hotmail dotcom
Chi Chu
  • 8457 Answers
  • Posted on Nov 06, 2010
SOURCE: I turned on power and red light is blinking but tv
Tries unplug,replug the tv back like an hour later.The tv now,should resetting itself back to the factory setting.The tv should work now.Not,than the tv power supply board have problems,not giving the tv it wright voltages anymore.The tv power supply board that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Anonymous
  • 1654 Answers
  • Posted on Mar 23, 2011
SOURCE: 15 months into owning our
My suggestion is that you get an estimat from a dealer on repair costs and you decide whether you want to spen money on a part or new set. This is a bad circuit board and probably the power supply. The repair will be around $200.00 minimum unless you get lucky and there is no major issues and the board can be repaired.
The service manual says. you have what you call a "shut down circut" it is for safety and when one of the internal boards gets shorted or is not working properly, service doc reads as follows
7 Blinks SOS:
Pin 93 of the MPU IC9003 monitors the status of the SC, SU, SD board. During normal operation, the photo-coupler PC6480 outputs a low to pin 93. If the SC, SU, or SD board becomes defective, a high is provided to pin 93. As a result, the unit shuts down and the power LED blinks 7 times
thiera blinking 7 times is cuase by a fualt in sc,su,sd board.
If the board shorted another before it went dead you could have other issues, thats why you need a tech to look at it and give you an estimate. You never know, this being so close to warranty they might work with you on it.
Anonymous
  • 1622 Answers
  • Posted on Jun 24, 2011
SOURCE: Blinking red power light on my Panasonic Viera
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hope this helpout to solve the problem...
Anonymous
  • Posted on Dec 10, 2011
SOURCE: panasonic TC-P42G15, switched off suddenly, then the red light flashes 5 times then off for about 3 seconds the starts flashing again, and has continued doing this for about and hour what is it and ho
David, what did you find out. I have the exact same problem as of two days ago.
1helpful
I have a Panasonic TC-P65ZT60 that flashes red light 3 times consistently
Page 50 and 53 of the Service Manual
https://www.manualslib.com/manual/2311596/Panasonic-Tc-P55vt60.html?term=3+blinks&selected=3&page=50#manual
3 Blinks
Yes
A1 and disconnect the
Blinking
Is the power LED
3 times
off or is it blinking 3
times continuously
at a fast pace ?
Replace the
K board
Applies to Models
TC-P55VT60
TC-P60VT60
List of boards likely to cause this
symptom.
No specific order
P, SS SC, A, K, Bluetooth module,
Cs, Panel
Panasonic TC-L47DT50 no picture no sound front lights com on
No picture or sound in my Panasonic TH-P42UT30A plasma ...
https://www.ifixit.com/.../No+picture+or+sound+in+my+Panasonic+...
iFixitAug 1, 2014 - Hi Ifixit,. I've got a Panasonic th-p42ut30a plasma tv that has a fault with it. The standby light is on (red) but it doesn't come out of standby.Missing: l47dt50
Panasonic Product Support - TC-L47DT50
shop.panasonic.com > Get Support
PanasonicSMART VIERA® 47" Class DT50 Series Full HD 3D LED HDTV (46.9" Diag.) ... Issues Addressed: Solves issue where the Emergency Alert System is displayed on the TVhours after the termination of the message. Solves issue where the Emergency Alert System is displayed on the TV hours after ...
Panasonic TX-P42X50B No Picture Or Sound ' Dead ...
? 9:00
https://www.youtube.com/watch?v=EanHoWLLpxU
Nov 6, 2014 - Uploaded by Electronic Workshop
Panasonic TX-P42X50B No Picture Or Sound This plasma television ... TV repair, clicking and will not power on, loud snap,no picture, etc.
Why does my Panasonic Viera VT50 have no picture and red led blinks 3 times
First thing, check the HDMI input and make sure it is firmly connected, same for the power cable, obviously. My Samsung goes similarly nuts if it detects no signal from the currently selected input but after 1-2 minutes it eventually stops and I can change the input source.
2answers
My Panasonic 50" plasma hd tv TC-P50X3 shows no power. There is no red light blinking. Wahat can I do to fix the problem
Check your stand by voltage on main board and power supply cable..should see marking on PS for Stby 5v. I you have the 5v change main board or A board it is not supplying your voltage back to PS to turn on. If you dont have 5v stand by change PS.
Power light red no sound no picture
Red light is standby, it turns green when TV IS turned on. If the red light is flashing then there is a problem and number of flashers are a code to indicate a fault type.
I have a Panasonic Viera TC-P50x1 HDTV. When I turn the power on the red light blinks 10 times. What is my problem?
Unfortunately the set will need serviced. I would contact Panasonic or whoever you purchased it from for warranty information.
Whats the best way to install a panasonic viera tc-p50x3 to a yamaha home theater receiver rx-v371 to a panasonic blueray dmpbd75 using dishnet work hddvr set top box
connect your blue ray and your dish net with hdmi cables to the amplifier than monitor out hdmi to tv .in your dvd configuration you must make sure that hdmi audio is activated .ps not to be mean but this is a very low quality dvd because it does not have fiber optique audio output but it can still work, for your dis net it all depends on what type of digital audio output
is available , ill be honest with you this is a good job .
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
