SOURCE: require an operator's manual for a bolen troy bilt ltx 14 hydro
Go to... http://www.buymtdonline.com/webapp/wcs/stores/servlet/FindingYourPart_10101_19502_-1 Scroll down to bottom left and click on Owner Manuals. You will have to have the model and serial numbers from under the seat of your mower.
SOURCE: HOW DO I GET A MANUAL FOR LAWN MOWER AND ENGINE?
please double check model # and let me know
after the g sholud be a #then 11
13AN77KG_11
SOURCE: I have a Troy bilt 17hp 42 inch cut ride on lawn
yes they have a charging system, not like a car but a charging system one the less. as i said before either under or around the flywheel. some newer mowers also have an electronic regulator.
SOURCE: troy bilt pony riding mower will go in reverse but
have a troy-bilt riding mower. place a gear in neutral and park it.
it dies instead idling. want to know why?
SOURCE: How to tighen the built on a Troy Built Pony 42in
You can't really tighten the belt on any of these mowers.
First make sure you have the right belt, if you measured the old one when it broke
then you were not using the size it was before it got all stretched out from use. Find a manual
or look around online for a source to tell you the size the belt should be new and get one.
Second there is a tensioner arm, spring, and pulley which take up the slack, this may
double as a clutch to put in slack when you depress the pedal. Make sure the pivot for the
arm, the spring, and the pulley/bearing are all in good shape.
Third there are belt guides which can also be worn and create slack, so check those and make sure
they are in good shape as well. I may not be the only one who ever put a belt on the wrong side of a guide.
Lastly make sure you have the belt on correctly, and nothing is bent, split, or warped.
