Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
Anonymous Posted on Aug 16, 2013
After 30 sec exposure on bulb my Nikon d60 has 20 second wait before it will let me take another picture. Why?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Nikon Master 102,366 Answers
  • Posted on Aug 16, 2013
Nikon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428472
Points
622693
The camera is performing noise reduction. To avoid this, make sure the ISO is set to 800 or less and Noise Reduction is turned off in the Shooting menu.
See "Noise Reduction" in the manual (page 108 in my copy).
Testimonial: "My ISO was set to 800 and then bumped to 200. I was shooting star trails and had the same problem with the 30 min exposure. I just looked on my camera and my noise reduction is set to ON! I will turn it off and see how that works. Thank you so very much! :-)"
Mike Groseth
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Jan 04, 2014
Mike Groseth
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
Helped
1045
Points
12
Your camera has to process all that info it collected over the last 30 seconds. Unlike film your camera has to write all the info to your memory card...you could possibly speed this up a LITTLE BIT by buying a faster rated memory card. Worth a shot but of course the faster the card is rated the higher the price tag!! Good luck!
1 Related Answer
  • 102366 Answers
  • Posted on Apr 06, 2012
SOURCE: incorrect exposure on NIkon D700
It sounds like you've got exposure bracketing turned on.
Refer to the "Bracketing" subsection of the "Exposure" section of the manual (page 130 in my copy). If you need a manual, you may download a copy here.
Slowest shutter speed
30 seconds, or when you put it om B (Bulb) press the shutter release button to start exposure and wait as long as you want. Then again press the shutter release button to stop exposure. You need to track time yourself.
1helpful
How to use time exposure
When you want to use the time exposure with your remote control, you need to be in the M mode (Manual) then you can select time Bulb. One step farther then 30 seconds. Then you can press the ML-L3 to start and again after some time to stop the exposure.
So, I finally figured out (with your help) how to find BULB in M. But, is it normal to press the ml-l3 button three times to get a picture. I did turn long exp nr to the on position. and the release in...
You should only have to press the button twice to take a picture. In the BULB setting, the first press opens the shutter and the second press closes the shutter. With the long exposure NR turned on, it doubles the picture taking time. If you take a one-minute exposure, for example, the remote will be ignored for a minute after the second press.
Try turning off the long exposure NR just to see whether two presses do the job. If it doesn't, please feel free to reply to this post and provide any additional information you can.
1helpful
How do you take a 15 or 30 minute exposure with the Nikon D5000 and how do you set the remote up to snap the picture in this kind of mode?
For really long exposures (longer than 30 seconds) you need to set the camera to the Manual exposure mode and set the shutter speed to bulb. This keeps the shutter open as long as you hold down the shutter release button. Since this is inconvenient, a much easier way is with the remote.
Press the [info] button to bring up the shooting information display. Press the [i] button to put the cursor into the display. Use the cursor keys to move to the release mode (fifth item from the top along the right edge) and press the OK button. The Quick-response remote mode (marked with an icon of the remote control) fires the shutter when you press the button on the remote. the Delayed remote mode (marked with the remote and "2s") gives you two seconds to hide the remote behind your back when taking self-portraits.
In either of the remote modes, when the shutter speed is set to bulb the shutter opens when you press the button on the remote and stays open until you press the button again (or the camera battery dies). This way you can press the button, go and do something else for a while, then come back and press the button again.
Information on the release modes is in the "Release Mode" section of the manual (page 65 in my copy). Information on using the remote control is in the "Self-Timer and Remote Modes" section of the manual (page 67 in my copy).
It happended something strange. I turned on the camera in P Mode and the exposure was 1/30 and aperture 5.6 for example. When I put in live view mode the exposure changed to "LO".
The camera and basically telling you that the shutter speed has dropped below 1/30 of a second. Any speed below this requires the use of a tripos. In "P" mode the shutter speed can drop as low as 30 seconds and the F-stop aperture will be the lowest your lens will allow. So to me it's operating correctly. Be aware that if you make a photo when the camera is in Live mode when "LO" is on the screen the picture could take several second to complete.
1helpful
2answers
In manual mode cannot set shutter speed to
The "--" is the equivalent of the bulb setting with the remote control. The first press of the button opens the shutter and starts the exposure. Another press of the button closes the shutter and ends the exposure. This is so you don't have to hold the button down and risk a bird flying through the beam (and to conserve battery power).
1helpful
Blue corners when shooting in BULB
With the same exposure settings, you should get the same result. When using Bulb in Manual mode, you also need to be sure you have set the lens aperture to the largest opening (lowest number). And don't forget to set ISO to 1600. Since the D80 has shutter speeds as long as 30" (minutes) I recommend you use them instead of Bulb, unless you need longer.
The blue areas are heat noise from long exposure -- other electronic components near the sensor are generating heat from the constant current flow. Be sure you check your Shooting Menu settings to set Long Exposure NR to ON and also High ISO NR to HIGH.
1helpful
Shutter Speeds
Hi, You can get into "Bulb" mode only when you increase the exposure more than 20 or 30 secs.
Try increasing the exposure by turn the wheel (towards left extreme) in manual mode. You should the Bulb mode now.
hope it works ... cheers
D40x Camera with mirror lens = black pictures
Usually tele lenses need longer exposure,and mirror lenses need more than normal lenses.Try with 1sec, half sec,( 2 in the speed dial, not 2" ) or quarter sec (4 in the speed dial) exposures.
One more thing, you need good sturdy stands to hold cameras.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
