SOURCE: INCOMING CALLS
Not sure it this is a solution for ALL your problems, but...
I had a similar issue: Phone rings, caller ID info displays then seems to hesitate, then displays only "INCOMING CALL."
The issue seemed to be caused by interference with other devices on the same line (in my case, an alarm system).
Tech support had me change a setting on my TRU9466 base unit (this is one of the PowerMax 5.8ghz models). This is how we did it step-by-step on the base unit:
MENU
GLOBAL SETUP
IN-USE LINE SETUP
select LINE 1
switch to TYPE B
This seems to have solved the Caller ID "interference" issue -- my Caller ID now displays as it should. The Tech Support person suggested trying that TYPE A/TYPE B setting on "OFF" if TYPE B didn't solve the problem, but thankfully, it did.
Now Cheryl, it sounds like your issue is more involved than this -- I didn't have any connection problems -- but perhaps they're related -- you might try my solution.
SOURCE: Uniden PowerMax 5.8 - system busy error comes up & no dial tone
Unplug the power supply to the base of the main handset, wait 10 seconds and plug back in.
SOURCE: I have a Guardian home security system and comcast
Guardian has the system programmed to answer so the can program it from their office when the bill isn't paid or to disconnect the monitoring..Usally it will answer after 9 rings,it has an answer machine bypass that works like this: someone calls the house and it rings a couple times then someone else calls right back it will give the data tones..Try it call your number and let it ring a couple times then hang up and call back and you will hear the data..Call and tell them you want the remote programming disabled..
SOURCE: My BT Verve 450 digital phone set won't ring out /incoming call
My GE cordless handset won't ring when it's on the base charging but it will when I take it off. I've taken off the battery and disconnect the phone from the wall to try to reset it, but it still doesn't ring.
SOURCE: our incoming calls are not ringing?
wen i receive incoming calls there is no ring or message alert
