Question about New Bright 115 Scale Radio Remote Control Dodge Ram Hemi RC Truck Car with battery pa
I have a new bright 1:15 scale radio remote control dodge ram hemi rc truck car that has been smashed but all i need is the battery compartment, ariel and remote
  • thomas mann Aug 16, 2013
    i can fix the rest
5 Suggested Answers
SOURCE:
bilink
  • 128 Answers
SOURCE: new bright 19.2v nicd battery problem
Don't throw away any NiCd power tool battery, Firestorm or Versapakbattery that does not hold a charge or does not give you the power youneed, you can get new life from your battery or device that containsNiCd batteries. icad batteries often die in such a way that they won't take a chargeand have zero voltage. This usually means they are shorted out bycrystal dendrite growth. You Can fix these shorted crystal dendrites by"Revitalization through Vaporization of Dendrites (RVD) Process".
You can get this guide from here
Posted on Jul 14, 2009
I have purchased 2 remote controlled toy cars from Costco over the years. These New Bright batteris and charges last only a few charges, and then they go bad. I am disappointed. I will go to Walmart and buy a new battery and see if it works better, if not, i will return to Walmart.
Posted on Dec 01, 2009
  • 3 Answers
the battery isnt lasting because it needs to be fully discharged (drained) before it is recharged. (this is only for nicd batteries)
Posted on Feb 22, 2010
  • 6 Answers
SOURCE: I have a new bright
ebay, or hobbyshop, or hobbyzone
Posted on Apr 22, 2011
This one as being fix
Try disconnecting the battery and the get inside and push buttons that are giving trouble. The body computer can be completely discharged then. Then reconnect the battery and see if it is normal again.
Feb 06, 2018 | Dodge Cars & Trucks
Remote not working throttle or steering ,and remote keeps saying low battery but has brand new batteries
FAQ - Answers for Common Redcat RC Questions
www.redcatracing.com/FAQ
Q. I installed batteries in my car and in the remote control but when I turn on the power ... You may have some things such as throttle working but no steering. ... If it doesn"t your cord may have come off track and you can simply open the rear of ...
Why is my remote control not working? - Geardup RC Ford ...
https://www.ifixit.com/.../Why+is+my+remote+control+not+workin...
iFixitFeb 19, 2015 - To fix this, you can replace the batteries. ... The GEAR'D UP RC Ford Mustang GT is a remote controlled car released ... Is this a good question?
Troubleshooting an RC That Won't Run - Radio Controlled ...rcvehicles.about.com > ... > Troubleshooting, Repair, and MaintenanceRadio Controlled Vehicles Expert. Share ... The batteries are often at the root of manyRC problems. ... Loose or broken wires can result in a host of problems.Radio Control FAQ ' RC Toys ' New Bright
Dec 25, 2015 | Exceed-RC RC Truck
How do i tune up, my 2004 dodge ram 1500 Hemi, i know what I need for parts, I just want to make sure on the best way to place them
TO DO A TUNE UP.YOU REPLACE AIR FILTER - SPARK PLUGS + WIRES.CHECK IGNITION SYSTEM.CHECK CHARGING SYSTEM.CHECK ALL ENGINE FLUIDS.CHECK ALL COOLANT HOSES AND VACUUM HOSES.CHECK THE COOLING SYSTEM.REPLACE FUEL FILTER.INSPECT BATTERY CABLES + BATTERY.IF YOU HAVE TO CLEAN BATTERY CABLES.TURN OFF RADIO FIRST SO YOU WONT LOSE RADIO CODE.CHECK CONDITION OF THE DRIVE BELT.IF LOOKS CRACKED OR MISSING RIBBS REPLACE IT.
Mar 18, 2010 | 2004 Dodge Ram 1500
Dodge Ram 2004 no dome lights or locks when key out of ignition
Sounds like you cut into one of the wires that that supply power when the key is off....you may need to get a wiring diagram for the truck and trace the wires down.
Cutting into the wrong wires is not uncommon in todays newer cars.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Sep 15, 2009 | 2004 Dodge Ram 2500
New bright 19.2v nicd battery problem
Mar 30, 2009 | New Bright Remote Control Toyota FJ...
Jan 17, 2009 | New Bright Remote Control Toyota FJ...
New Bright 115 Scale Radio Remote Control Dodge Ram Hemi RC Truck Car with battery pa Logo
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
Jonah Oneal
gerry bissi
Are you a New Bright Toy Expert? Answer questions, earn points and help others
