My kocaso m736 tablet won't unlock and I don't have a password and its like the screen is broke but I don't have any cracks and never dropped it. Please help me
Have you tryed the reset button???
how do I use the reset button???
i am on the page where i have tosign in to my google account but i forgot my email & password & i cant to anyting else please help
how do i find the reset button
i am locked from doing anything im am stuck on where u sign in thru google an it will not let me leave the page
SOURCE: my toshiba tablet won't let me go past the welcome screen
If this is under warranty take it back. If it isn't power the unit on with just the battery powering the unit. When you see the Windows splash screen drop the battery out after the screen goes black put the battery back in and press the power button. This should bring up the on screen menu telling you it failed to start or shut down correctly. Select, Boot in Safe Mode and see if the system will power on. If that fails you need to do a system restore. To access system restore options power the unit on and press and hold the F10 key, this will bring up the restore Windows options. From that menu select to restore your operating system. If that fails you will have to do a complete restore to factory default settings. If that fails you will have to replace the hard drive.
SOURCE: my coby tablet won't open
Hi s112ronnie,
If your Coby tablet suddenly has no response or powers off, an elec-trostatic discharge may be the cause. In this circumstance, please follow these procedures for recovery:
1.Reset the player (use a paper clip to gently press the Reset button (on the bottom of the player).
2.Turn on the unit again
NOTE: Back up your data to an external source prior to performing reset.
Hope it helps.
Thank you for using FixYa.
SOURCE: i dropped my android tablet
You can get the part at android Repair and there is a guide that shows you how to put in the part at tablet Repair Guide.
try to hold your power button and home buttom at same time or 1 min it will rebooth it
SOURCE: i have a craig touch screen tablet and i forgot my dot password how do i reset it?
Unlock windows password,the easiest way I ever use is to adopt Windows Password Reset ,just a few steps:
Step 1: Download and install Windows Password Reset
Step 2: Burn Windows Password Reset Std ISO file to CD/DVD
Step 3: Put in your newly created CD and remove your Windows Password.
For more details,go to: http://www.windowspasswordreset.net
