RIM BlackBerry  Pearl  8100 Logo
Anonymous Posted on Aug 16, 2013
507 error blackberryforums - RIM BlackBerry Pearl 8100
Anonymous
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 51 Answers
  • Posted on Aug 17, 2013
Anonymous
Expert
Level 2:
New Friend:
Cheetah:
Answers
51
Questions
0
Helped
5324
Points
101
It is a problam of ur imei so plz contect the blackberry company
2helpful
2answers
Reading jvm 102 error rest
Hi, you have to follow the instruction below to correct the jvm 102 error reset problem..
Step 1
Very Important!!!!
It is important to have the following software installed on your computer (at home and at work if you can):
1 - Desktop Manager - Hopefully this is already on your computer, if not click here:
https://www.blackberry.com/Downloads...93E4F3BB068C22
2 - Device Software for your BB - Here is the link for you to get the latest OS for your Blackberry
http://blackberryforums.pinstack.com...ll_models.html
3 - Java Commander - You can download it here:
http://blackberryforums.pinstack.com...d=5&linkid=452
4 - Backups - You should be creating a backup of your device data regularly, e.g., as often as you update your calendar and/or phone book, or at least once a month. If you do not already have a data backup, you are out of luck (SOL) as your data is gone.
STEP 2
The Process
From Pinstacker JTReeves:
You should be creating a backup of your device data regularly, e.g., as often as you update your calendar and/or phone book.
If or when you get a JVM Error 102/Reset message, do the following:
1. Connect your BB to the computer.
2. Run JL_Cmder
3. Choose option 5, wipe the device. This will delete all files - OS and data - from your BB. The BB screen will show JVM Error 507. This means the BB has no files installed.
4. Using Desktop Manager, reinstall your software. When you run the Application Loader, check all the available boxes.
5. When this process completes, restore your most recent backup file.
You should be back to normal, with the exception of having to reregister OTA or other 3rd party apps. Save their reg numbers in your Memo app so that you have them handy.
Error 507 please help
I'm sure it requires you to reinstall the phones firmware. Go to the following link to download the firmware:
http://www.blackberryforums.com/rim-software/1871-blackberryos-4-x-download-faq-upgrade-downloads.html
2answers
My black berry said jum error 513
Step 1
Very Important!!!!
2 - Device Software for your BBHere is the link for you to get the latest OS for your Blackberry
3 – Java Commander – You can download it here:
4 - Backups – You should be creating a backup of your device data regularly, e.g., as often as you update your calendar and/or phone book, or at least once a month. If you do not already have a data backup, you are out of luck (SOL) as your data is gone.
STEP 2
The Process
2. Run JL_Cmder
do all this and your phone will be revived
Jvm error 547
STEP 2
The Process
2. Run JL_Cmder
I want to connect my ar-507 gray digital copier to pc UBS port
Did you use a pcl driver? What was the error message?
1helpful
Reload error:507 curve 8900
well you have done great so far. Error 507 means that JL-CMDER has done its job and wiped all applications off your phone. So just do the next step by connecting it to your 4.7 Blackberry Desktop and select App Loader and install the OS and Applications on the phone. Please write again if you need more help
1helpful
Jvm 102 error
The problem is a java related problem. Your only option is to reinstall the OS after wipeing the handheld clean. Here is a little step by step for you.
1) Get javaloader (can be found on blackberryforums.com)
2) Get the latest Blackberry OS from RIM which you can get HERE
3) Run the Blackberry OS installer you just downloaded.
4) Shutdown Blackberry Desktop Manager on your PC.
5) Open a command prompt window.
6) Change to the folder where the javaloader program is on your computer (If you put javaloader in C:WINDOWSSYSTEM32, then you do not need to change folders in the comand prompt window.)
7) Execute the command "javaloader -usb wipe" (no quotes), and wait for the handheld to reboot with error code 507
8) Disconect the handheld from the PC, restart Blackberry desktop manager, and reconect the blackberry to your pc.
9) You will be prompted to "upgrade the OS on the handheld" follow the prompts, and when you BB reboots, it will be reloaded with the factory defualts.
10) Login to nextel.blackberry.com, and resend your service books.
11) Restore your BB applications, by reinstalling, or redownloading them.
I hope this helps, if it does please rate accordingly, Thanks, David
4helpful
3answers
My blackberry 7290 showing "error 507"
good Days
I have problems whit my BlackBerry 7290. Wen starting it is showing "error 507". pls help me how unlock it.
post solution for me here..
thank you for help me
my regards
http://itot54joni-mobile.blogspot.com/2007/11/solve-blackberry-error-507-505.html
6helpful
5answers
Error code 507
dear,
i have the problem of 507 error on my blackberry model 7290. please be of help and tell me what to do about it.
thanks
ogbonna
Top RIM Computers & Internet Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Alexander
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
