Dear,
I have one Bentley Continental Flying Spur Cars. now I have one problem for the rear door child safety lock. It's lock now. I try to find out the unlock system, unfortunately, I have missing my user guide that I can not unlock any more. Could you please do me a fever to solve this problem. Thanks a lot in advance.
SOURCE: how much oil does 2006 bentley flying spur take
Call Advance Auto Parts. They should be able to look it up.
SOURCE: Bentley Continental Fluying Spur service display reset v12 '2004-
The real repair is to have the vehicle serviced by a Bentley dealer. The other option is as follows...Press and hold the trip button / While doing this, turn the ignition key into the on position / Let go of both, and you will see the words "service reset" on the drivers instrument panel screen / Now press the silver knurled roller switch "OK" on the right side of the steering wheel controls, by the menu button. This will confirm the request.
SOURCE: bentley flying spur reset service notice
I loose all electronics. Car stalls, can't get the ignition key out and the hazzard lights don't work during this time. after a period of 5 minutes the car starts.
SOURCE: 2006 bentley continental w/dead battery. How can
Normally if you use the key and turn it to the left and then to the right the car will start on the resident battery and all will be well. Do not use the start button. If all lelse fails then put a battery charger into the two cigar light sockets for 1 hiur at max 10 amp with ignition turned of and with wires trapped in closed door to switch all coutesy lights off and then there will be enough for the trunk lock to energise. If it is later spec there will be a handle in the trunk accessible thru the centre arm rest by an arangutang!""
