Lately my TV has very dark borders around the edges of the set. I thought it could be the bulb, which I replaced. I resset the timers still no fix. The dark borders around the screen are aprox. 4".
Dark or low light tv shows are horrible as I can really only make out the middle of the screen.
Check any magnet or some speaker are near ur tv . Off it for 1 hrs , re on it & check
SOURCE: The picure on my Philips 62PL9774 TV is dark around edges
I believe that this is an LCD projection TV. I haven not worked on this model of set, therefore I will comment genericaly.
There is probably dust accumulation, or maybe a problem in the optical path, or a problem with the lamp. The set would have to be checked for this type of fault to begin with. There are other types of conditions that can cause what is known as shading problems, but are mor rare than what I descibed.
Jerry G.
SOURCE: I have a Philips Cineos
open up the back of the tv and look to see if any of the capacitors on the power supply or video board are swollen or oozing out stuff....if so replace them and should work
