I have comcast custom dvr 3 device universal remote and Microsoft Xbox 360. I would like to use the remote to control the xbox. The remote works for the most part except the (red) ok/select button. Ok/select button seems to work only for the cable box. Is there a way to unlock the button to work with xbox 360 as well?
Sorry, the Red Button won't work, but you can map the A button on the Comcast remote instead. It's almost the same thing... Your fingers will barely know the difference.
1. Press the Aux button at the top of the remote.
2. Hold the Setup button until the Aux button flashes twice.
3. Enter 994 on the keypad. The Aux button will flash twice again.
4. Now push the Setup button once. Enter 00001.
Finally, push the A button The Aux button will flash twice. You now have the A / Select / OK / Green button mapped on the Xbox360.
--If you want to switch the A button back to default, just do the same sequence but this time push the A button twice.--
Some of the remotes come defaulted with the primary control buttons locked to the cable mode. Check the user manual on how to unlock them and it may fix your problem.
5 digit code :- 10463, 11409, 11904, 11911,11935 (Comcast Universal Remote )
4 digit code :- 0463 (COMCAST - CUSTOM DVR-3 DEVICE UNIVERSAL REMOTE CONTROL)
ok
Do you have anymore code for the xbox for this remote? For example the back button?
do you have a code for the back or B button? THe other code worked great thankls.
Charter remote control
