RIM BlackBerry  Pearl  8100 Logo
Anonymous Posted on Apr 07, 2009
Blackberry pearl wont stay on and red LED light keeps flashing
My phone wont stay on and when it does come back on it shuts right back off. the LED light on the front keeps flashing red. ive taken the battery out and everything and nothing seems to work. help please!
  • Anonymous Apr 10, 2009
    same thing for me
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 09, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1138
Points
Blackberry shuts off and red light keeps flashing. I take the battery out and put it back in and it still wont work. Then randomly it will turn on and work for a bit. Im so lost, please help!
The flashing red light is telling you that the battery is almost drained down to capacity and that the phone must be plugged in now. When the charge is this low you are going to have to leave the phone recharge for at least 12 hours before trying to use it again. Once the phone is turned back on, the phone will reset itself. Good luck.
2answers
Hi my blackberry pearl has a blinking red light and it wont turn on
LED indicator keeps on blinking (red light) but no screen its water dep i rehot the phone 100%ok done
Solid Red LED... going nuts!!!!
What you need to do is reinstall the update I would do this by backtracking to a previous version of the software then reinstall the update again just make sure it is the right update for your service provider and then it should be fine :)
Kyle
Blackberry pearl
oneof my old phones did that and its no help to fix it so you will have to buy a new one it means that something is wrong with the device that keeps the phone running and going right it burned out.
Red LED light keeps flashing after I open a message
The red light is telling you that your phone is on. It will flash regaurdless if you have a text or not. When you charge it the light turns green.
Thats how they're made :)
2helpful
2answers
Doesn't turn on, Red LED light stays lit
Try restoring the blackberry using the blackberry firmware update utility, if the problem persists, it's a logic board issue. there are blackberry repair websites that show you how to do the replacement yourself, otherwise here is a service that can repair any Blackberry Bold, Storm, Pearl, Curve, 8800 for screen, lenses,
track balls, usb ports, waterdamage etc.
The website is: Blackberry Repair
2helpful
2answers
Red led light is flashing while charging and it won't turn on
I just called Verizon Wireless who said that the phone may need to be charged completely for a few hours. Try taking the battery out and putting it back on as well.
13helpful
2answers
Green light flashing on blackberry pearl
This just means that the phone has coverage. under options and then screen/keyboard, you cna turn it off by where it says LED coverage indicator.
My blackberry 8110 will not charge
this happened to me and i just shut the phone down took out the battery waited 3-4 mins put battery back in do not turn on phone but put it on charge and it should be ok.
283helpful
42answers
My blackberry pearl 8100 wont turn on
I have an answer for the 3-2 red light blink w/black screen. Remove the battery, hold the end call button and put the battery back in. The red light should stay on for a while now. Push and hold the call button and alternate with the end call button untill the hourglass shows. Allow some time to boot up. I stumbled upon this, so if this doesnt work, try simmilar procedrues. I did get mine to work. Good Luck, dont give up, it flashes that 3-2 code for a reason.
Top RIM Computers & Internet Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Alexander
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
