Our freezer is just over a year old and it's model GLFU1767FW2. It a large upright freezer with electronic display that beeps every twelve hours. I've had so many people out to try and fix it. The display and control panel have both been changed and it still beeps. Any ideas. The red warning light is always on and the display flashes d and temp. alternating or ce and temp. alternating. Any ideas?
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
