LG DU-42PX12XC 42 in. Plasma HDTV Logo
Posted on Apr 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The left side of my LG plasma has vertical lines. right side has clear picture.
  • Anonymous Apr 15, 2009
    vertical lines on lg plasma 50 inch when cold lasts for a few minutes
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 07, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
889
Points
It sounds to me like one or more of your buffer boards has gone bad. You will probably have to have it looked at.
Todd Hill
Level 2:
Sergeant:
Champion:
  • Expert 433 Answers
  • Posted on Oct 30, 2011
Todd Hill
Expert
Level 2:
Sergeant:
Champion:
Answers
433
Questions
0
Helped
398922
Points
665
Ck ribbon cable on x board
Took lg plasma tv off wall when i put it back there is a fine vertical line which changes colour
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELP IN SOLVING THE PROBLEM.....
LG DU42PX12X - red and pink vertical lines.
I know this post is old,
But I had the same problem.
I was able to fix it.
Heres a write up I did on the "How To".
I added pictures and diagrams too.
http://jasonkoller.blogspot.com/2011/02/lg-du-42px12x-plasma-tv-fix.html
2answers
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
1helpful
2answers
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Plasma TV technical difficulty
if you can still see the picture its most likely the control board that's going bad, you will still need a tech out to fix the issue.
Left side vertical color lined right side clear picture half screen
I solved the same problem by replacing my digital board. Cost $118.00. Been working perfectly for several months now.
42" LG Plasma with 4" vertical lines at each end
LG service is non- existent . The only solution that I can suggest is "Give a wide berh to LG products. Dont ever touch any"
2answers
Red line on screen
The vertical line, in my case, was due to a bad contact on the flexible printed circuit. I fixed the problem by using a piece of a rubber eraser to apply downward pressure on the flexible circuit as shown in the picture. To locate the faulty section lightly push on the flexible circuit from lef to right untill the line dissapears. 9f78570.jpg
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
