I have a 1994 Isuzu pickup 2.3l. Over heating changed water pump and top hose and now the fan stops whene I put a rolled up magazine in it. But I also suspect the intake manifold gasket
oVER HEATING HAS
Many causes, not 2 like in your post over 10
and many symptoms not just 1. in most cases.
its not a gasket,
what makes you think its overheating
1: steam? go that?
2: engine power loss and ping.?
3: gauge told you ? in cluster, some lie , is yours fibbing (tests)
4: water blasting out the side fail tank (expansion tank>?)
5: leaks to ground>?
6: leaks to passengers toes, heater core or its hoses there leaking.
7: over heats only parked, ??????????????
8: fan dead. (that newspaper trick not a real test) many fans are RPM operated, not simple heat locked, as you think. we use RPM optical meter to test fans.
causes.: lots.
A: thermostat bad, they last about 6-7 years and die all do.
B; RAD cores blocked, we use a $15 IR thermal gun aimed at all tubes top/bottom, and find dead tube with no effort at all.
C: pump bad, no its ok , its new.
D; fan belt slips.
E: fan dead, but would not over heat moving fast. so....
F: junk and crud packing a/c front of RAD, condenser, or RAD.
G:engine block full of MUD, from zero service and flushes in 20 long year.
H: cam belt slipped now timing way off, and huge heat load from poorly burning fuel (and late)hits cylinders walls, x4 and huge heat load on the water jackets and with 1 weak item above, pushes said camel off the cliff, is sparking timing right if not cam slipped a 1minute test with any timing light every made.
and more, lots more,
not running 50% AF?
running pure water> omg
