Refer to the trouble shooting at Nintendo. Your screen may not be working due to the game your playing if any. If that's not the case you may need to recalibrate your touch screen.
http://www.nintendo.com/consumer/systems/dsi/en_na/trouble_screen.jsp#respond
SOURCE: touch screen not working
there is a problem with dust and dirt getting between the casing and touch screen. get an old toothbrush an give it a brush all the way around that should cure it
SOURCE: ds lite touch screen
Try taking the battery out then putting it back in, if that doesnt work i have no idea.
SOURCE: Both Screens Flicker after trying to replace touch screen
I finally solved the flickering problem on my DS (!), after I made my 1st engineering attempt overhaul shell, top screen and broken right hinge. Was really frustrated about the flicker afterwards, and opened up unit back up too many times to debug (risked damage to cable ribbon everytime!).
Anyway turns out there's 2 hidden screws (location: inside the battery compartment near where the front 'volume slider' is located) that adjusts the flickering (like how you need to calibrate an LCD monitor from doing same flickering effects) . You'll need a really (really!) small philips (+) screwdriver to do the adjustment.
Open up the battery cover with the VOL label upside down & facing you. The adjustment screws are recessed deep inside the plastic...a right and left screw. With the DS turned 'ON' to see the screen (whether you twist your neck to be able to see or have a mirror on the table in front of the DS)....slowly/carefully turn the screws to adjust until you like the clarity. That's it. The right screw = bottom screen. The left screw = top screen.
Now.... on to figuring out how to replace or fix the broken Power toggle switch that I snapped off! Currently using the toothpick method, but that's getting old! Any suggestions, I'd appreciate it!
SOURCE: calibrate touch screen
when you turn your nintendo on you have a health and safety screen touch it and it will come up with your homepag. use the arrows to get to the bottom middle button. this will look like a nintendo with a box around it.press a when you have got it. move across to the last button and press a again. thn click twice on the screen and it will be in the middle then press enter
SOURCE: screen wont work with stylus
I have many touch screens in stock and will replace for $30 each
return shipping on same day.
[email protected]
