I have a Kenmore 70 series gas dryer that is not heating up. I used it one night and the next day it would not heat. However if I continue to restart the timer the clothes eventually dry but not by heat.
Help!!!!
my kenmore 70 series gas dryer does not heat up what should I check for to fix this problem.
SOURCE: Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Unplug and turn off the gas feed. The fuse is located in the back of the series 70 attached to the lint housing near the bottom. About 1-1/2 inches long. Easy to remove, only two contact wire attachments. Note which wire goes where. Under $10.00 at an appliance parts store. Start with this fix.
If still no heat take out the ignitor assembly, located in the front, lower left. It is attached to the base of the dryer by 3 screws, the gas feed and two electrical wires with removable metal attachments (note which attachment goes where). The entire assembly will come out and the ingitor is attached to the front end. I took mine to the appliance parts store and it tested OK so it was the fuse. The owner helped me locate the fuse and suggested I try this first. The ignitor coil is about $25.00.
Both of these were easy enough for a novice (like me) to do. It saved a lot of money.
While the dryer was open I vacuumed out all the dust and lint and checked the integrity of the belt.
Good luck.
You probably have an open thermal fuse, the dryer will run in some cases and not heat, Just moving air across you clothes will dry them however it takes forever.
If you are electrical or mechanical replace the thermal fuse yourself if not call someone you trust, you can purchase thermal fuses on line from Sears.com just do a parts search for you specific dryer.
SOURCE: Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
SOURCE: sears kenmore dryer 70 series will not dry clothes, unit does not
faulty heater element try replacing it at rear panel bottom left panel behind drum at rear cheap to mend yaself
