SOURCE: detergent dispenser stuck
Had the same problem here today, the softener dispenser blue plastic piece was loose jamming the whole dispenser tray, to resolve remove top cover, two screws on top rear, slide the cover towards the back, you will then see the detergent dispenser, press the right clips and pull it off slightly at the back; do not put too much pressure and try to remove the cover completely, just pry the plastic cover a bit then pull the detergent tray it should come right out.
