The light bulb has burnt out melting the lighting mechanism and plastic covering. Can this be repaired?
New frige smell? not rotten food. something to do with motor maybe stale water in pan. how do i clean it. i see some screws do i need to unscrew something to get to pan. where can i put bleach or clorox? have had for 1 day and the odor is annoying. like a plastic smell. don't think its wiring shorting or anything like that but who knows. landlord replaced my leaking frige with this used one. magic chef model# mcbr1020w
hy60yhur r1340 LBP
huayi compressor 1005057074
SOURCE: The lights in my Kenmore Elite refridgerator won't go OFF!
replace your door switch it is stuck on the open part
SOURCE: The light bulbs inside my
You have a bad main board with a relay stuck shut. Call an LG dealer and ask them if there is a service bulliten on your model. If there is, your parts are free.
Testimonial: "This is exactly right. Both the parts and labor were covered by LG, even though the fridge is almost 3 years old."
SOURCE: the light has not been turning off which melted
Karri,
I experienced the same problem with my LG refrigerator (model LFC25760ST). Came home from a weekend trip only to find that the light bulb assembly had melted and dropped onto the top shelf. The interior of the refirgerator compartment was very warm (est. 70 to 80 degrees) and everything in it had spoiled. Fortunately, nothing worse had happened. (According to consumer information on the Internet this LG refrigerator is suspected - but not proven - to have been the cause of a couple of house fires.)
There was no recall, however, because the reports to the Consumer Products Safety Commission were for less than 5% of this model sold in the U.S. But if you contact LG customer service (1-800-243-0000) whether your unit is still under warranty or not they should send someone out to replace the lamp assembly at no charge to you - this one with a heat sensor that serves as a backup to turning the lights off once the doors are closed.
Newer LG refrigerators have LED lights instead of incandescent light bulbs so they don't produce enough heat to warm the interior of the fridge or melt the light housing.
To learn more about other folk's similar experiences with these LG refrigerators just do an Internet search using "LG and "LCF25760" and "melted plastic." (Note: Leave the other letters after the five numbers in the model number off - they only refer to the exterior finish [i.e., "ST" = stainless steel] and unnecessarily narrow the search so as to miss some links.
Good luck with LG customer service.
grm
