Check all battery canles for corrosion and make sure they're tight. If cables are ok. Try to rotate the engines manually to make sure the engine is not locked up. If it rotates, test battery. If battery checkout good, try to activate the starter directly with a wire or screwdriver on the starter solenoid. Most likely u have a loose or corroded battery cable
Indicates the good battery has a dead cell and is not good under load
have it load tested
SOURCE: Starter fails to start.
I'm having the same problem. The dealership keeps telling me it's the starter. I've replaced starter and still have the same problem. I have had all the wiring and new key swith put in and still have the same problem. I guess were in the same boat!!!
SOURCE: 1994 Toyota Camry 4 cylinder Starting problems
your starter is bad.... the two contacts inside the solinoid are worn out only way to fix is replace the unit as a whole bet ya you get click click click then my start.. bet my life on this one been fixin toyotas for 20+ years
SOURCE: new starter good batt. only clicks wont turn over 1995 montero
The Batt does not have a full charge or it is the wrong cranking AMP's for the car... find out if it is the right Batt and also that it is put on a "slow charge" over night or at least 6 hr's
SOURCE: 1994 Toyota Tercel Starter Problems
sounds to me that you have an igniton problem not a starter problem and or if you have or had an alarm system could be cause if u do give me feedback and i will explain but seems that your starter is fine from what u say but if you think in terms of the elemts to start a vehicle batery gives pwoer to ignition which sends to starter which gives spark etc i would check you ignition system something is causeing a short and not alowing starter to function
SOURCE: i have 2003 cad cts mt new battery,new starter
does the vehicle have an anti theft device on it if so it may need to be reset. usually all you have to do is unlpug the negative batt cable. for about 5 mins.and reconnect it. if this does not solve the problem look i the owners manual to see how to override the system.
