Question about Polycom SoundPoint Pro SE-225 Corded Phone
Polycom SoundPoint Pro drops line after call waiting ignored
When I am on the Polycom (either Line 1 or 2) and another caller calls in (on either Line 1 or 2), I hear the callwaiting sound. Once I ignore the second caller and continue my conversation with the first caller, when the second caller hangs up then all the lines go dead and all calls are ended. Has anyone experienced this and knows how to solve the problem?
5 Suggested Answers
SOURCE:
SOURCE: You are on a conference
Has this been fixed yet?
Posted on Nov 19, 2008
SOURCE: MWI doesn't work on Polycom SE-225
The issue isn't exactly resolved. This appears to be due to an incompatibility of the Polycom Se-225 on our Meridian 1 phone system. But Converse handsets with MWI work fine. I have a partial solution by disabling the lamp (LPD on class-of-service), while leaving MWA setting. This allows the interrupted dial-tone when the user lifts the handset.
Posted on Dec 10, 2008
  • 5 Answers
SOURCE: Polycom SoundPoint 550-Only Showing 1 line
On the phone, press the menu button, then status, then IP status or whatever and get the phone's IP address. Write the ip address down. On your computer, open up a web browser and input the phone's IP address into the address bar and press enter. This should arrive you at the web gui for that phone. It'll probably ask you for login credentials; by default, the name is "Polycom" (yes , it is case-sensetive) and the password is 456. Once you are logged in, you should see several links like "General" "Network" "Sip" and "Lines". click on Lines. under "line 1", you will see the configuration for that line. simply duplicate the entries for lines 2, 3, and 4.
Posted on May 31, 2010
taran_2005
  • 10515 Answers
SOURCE: I have a polycom soundpoint
I am sorry to hear regarding the problem.
I initially thought it could be a bad display, however as you could see the caller ID on few occasions, and moreover the missed call details, that completely rules out that being the case. The problem you mentioned are highly suggestive of a hardware problem and would need repair. Unfortunately, there is no ' quick ' fix for the same. Whenever these phones are aged out or there is an electronic circuitry problem, it could cause these funny things. As the other phone is providing the caller ID on each call, that simply excludes phone line being an issue or the activation cause. We have seen such issues in our shop, however we never recommend repair as the cost could be high as compared to the cost of the used one on auction sites such as ebay or a new one with warranty.
I wish i could have a better solution, however new instrument is on the cards unless you want to use this unit the way it is.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 12, 2011
How much internet speed is required to run polycom soundpoint 330
For one line, you need both upstream and downstream of 90kbps for good quality.
Mar 02, 2011 | Polycom SoundPoint 330 IP Phone
Polycom 225 SE. Can`t make a full duplex conference call.Always it works in simplex mode. Thanks. Edward
The 225 is full Duplex and I can't see any reason why it should not work. I can only suggest menu, system settings. restore default, and see if that changes anything.
What exactly is happening when you do a conference call?
Procom have a support section
manual here
http://support.polycom.com/PolycomService/support/cn/support/voice/soundpoint/soundpoint_pro_se225.html
support here
http://support.polycom.com/PolycomService/support/us/support/Contact_Us.html
worth sending them the question they can only refuse to answer or try to charge you!
Feb 02, 2011 | Polycom SoundPoint Pro SE-225
How do I transfer a call from the Polycom SE-225 phone?
Follow these steps :
1.1
Press the function (FCN) button on the handset while on a call and then press the number "2" button. This will place the call on hold and you will hear a dial tone.
2.2
Call the number or extension of which you want to transfer the call.
3.3
Push the FCN button on the keypad and then the number "2" button and immediately transfer the call. You do not need to wait for the other party to answer.
Oct 29, 2010 | Polycom SoundPoint Pro SE-225
Polycom SE225: my verizon line provide caller id does not displa
Due to the age of the SoundPoint Pro, it some of its features are not compatible with newer phonesystems, such as CableVision. There are no software updates for the SoundPoint Pro, and as long as the Caller ID is enabled there are no other settings or adjustments that can be made to workaround these kind of problems unfortunately. I recommend contacting your service provider to see what kind of caller ID signaling they are using; most likely they will be using a newer digital system, or MDMF which is not backwards compatible with SDMF or earlier CID receivers.
Dec 05, 2009 | Polycom SoundPoint IP 501 IP Phone
I have no dial tone on my SE225 and have tested all the lines and PSU which are working. Is the phone faulty or is there some setting to adjust?
I have a polycom soundpoint pro SE-225. when i either pick up the hand set to make a call OR press the speaker button to make a call i get a dial tone for a few seconds, then the dial tone jumps up and gets real loud for a few seconds and then goes completely away and will not let me make any calls. Any ideas what the heck is wrong??
Oct 14, 2009 | Polycom SoundPoint Pro SE-225
Jul 29, 2009 | Polycom SoundPoint IP 550 IP Phone
Dec 09, 2008 | Polycom SoundPoint Pro SE-225 Corded Phone
Polycom SoundPoint Pro SE-225 Corded Phone Logo
93 people viewed this question
Top Polycom Lands Phones Experts
Joseph Wright
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
