Dell Dimension 2400 PC Desktop Logo
Posted on Sep 05, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix a dell monitor dimension 2400 power button broken
When I turn on & off the power button it moves inside the monitor and now it won't even turn off. The power button needs to be fixed. Any suggestions on how I can do this myself will be appreciated. Thanks, Andy
  • 14 more comments
  • Anonymous Nov 18, 2007
    crap ! i hav same problem-but this button just wont push in to shut off -all the other buttons do work -seems stuck,but no amt of playing around will free it
  • Anonymous Dec 07, 2007
    I just set the power button to 5 minutes and theen it powers off.
  • corina0_1 Apr 05, 2008
    any link where i can get the buttons from? I can put them myself
  • Anonymous May 25, 2008
    power button stuck off and will not turn on
  • anilgoud Jun 02, 2008
    I have problem with my monitor switch.when ever I switch off my UPS it automatically gets off,again while restarting we must press the button several times. Now-a-days it became 2 worst unless we keep any support like paper it's not working.
  • sdorn00 Aug 23, 2008
    I have the same problem.  Someone told me to replace my power supply, but I don't want to replace the power supply unit if it's the buttons on the front of the tower that are the problem.  Anyone know if there is way to test the buttons on the front of the tower?
  • krbrown4797 Oct 08, 2008
    I have a Dell 1707FPc Monitor with the same problem. When I pushed the button to turn the monitor off, I felt it crunch. Now it won't turn on. You would think such an obvious manufacturing defect would be eligible for some kind of consumer action against Dell.
  • trailingedge Nov 16, 2008
    I followed the bezel removal instructions, and took all the plastic bits off. Found the power button broken beyond repair, so I cut the bezel away enough to get at the actual switch underneath. Works fine, though the LED power light is rather bright now. The switch is actually off to the left of the center of the power button, the LED is right under it. If I had better tools, I probably could have made it look nice, but for now, it works.
    Now, the previous owner is happy with her new 22" widescreen and I have a free 17" with yet more USB ports.
  • bruce26547 Dec 30, 2008
    No idea how this happened. Rarely use the power button. Luckily, the power button was in the on position when it broke. As a side note, I only noticed this problem when I had my power saver to the monitor set at 20 minutes. So every time I came back to the monitor and it had turned off it would not come back on when I moved the mouse. The power LED light would turn green and then just turned off. Switch wouldn't work and I had to unplug the monitor for a few seconds and plug it back in. The monitor would then come back on. Don't know why. I now have the power saver for the monitor set for never.
  • Piso Mojado Mar 10, 2009
    Broken power button on a Dell 2407.  While I was prepared to remove the bezel and attempt one of the fixes mentioned here, I found that by manipulating the button back into it's original position with a pair of tweezers it would work well enough to turn the monitor on.  I think I'll just leave it on for now or power down at the UPS.  Good luck to y'all.
  • Anonymous Mar 28, 2009
    i have a problem with my dell computer. When I turn on the computer it shut off, then all of an sudden it turns back on. it turn on & off by its self when i turn on the computer.
  • Anonymous May 08, 2009
    Grrr... My monitor is 16 months old. ON/OFF switch broke in the ON position and now I cannot turn it OFF. Even with a 3 year Warranty (purchased), Dell won't repair it.
  • Anonymous May 17, 2009
    Broken power button is a very common defect. It breaks down after roughly one year of normal usage.
  • Anonymous Feb 22, 2013
    This solution basically work for the power button on the W1900 Dell LCD TV monitor. To gain access to the power button. Remove the rather heavy stand (unsnap it with the toggle button on back). Six screws on the periphery of the black plastic back case must be removed. Also, remove the four small screws on the back where the stand was attached. Then gradually, gently unsnap the entire back cover by gently prying around the edges. Then you can see the problem with your power button.
    Generally, this applies to the Dell W1900 LCD/TV monitor. Remove the rather heavy stand. Remove six screws around the outside edge of the back cover. Remove four screws where the stand was attached on the back. Then gently pry off the rear cover. This gives access to the power button (and all the buttons for that matter). Then pick the best solution. 1. fashion a pushpin solution. 2. leave in on position and use remote or a external on/off power strip. 3. another solution.
    Dell W1900 ......I posted something more detailed below in solutions. Please be safe and unplug before you work on the monitor.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 14, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
30482
Points
43
The last guest left us hanging with, "easy fix" so, I ventured ahead to see what I could see by opening up my lcd, which was a puzzle in itself. After UNPLUGGING the monitor and removing the stand and the 4 obvious screws in the back, turn the monitor onto its back and placing your palms against one side of the monitor, and using your FINGER TIPS, gently pull back the plastic lip away from the LCD screen. Move along the lip, doing this a little bit at a time. You'll hear and feel it snap loose. Repeat on the remaining three sides. It may take a few rotations to free all the sides, doing a little at a time, so as not to put undo stress on the plastic that is not yet loose. The bottom lip from behind which lies the offending "on/off" button will not move as freely as the other sides because of the ribbon cord that attaches the circuit panel to the main body. So STOP pulling when you feel it become taught and carefully turn the monitor onto its face to complete the face's removal. Undo the cloth tape that secures the ribbon cable to the monitor. This will give you the necessary slack you need to do your dirty work. BTW, we're not disconnecting the ribbon cable from its connections- that would be bad - just remove that haphazardly placed piece of tape used to keep the thing snug and save it for when you're ready to close it back up. OKAY! There a four tiny screws that affix the green circuit board. You'll need a thin, jewelers type phillips head or a one from a synthe-sized tool set to remove these. Now, if your issue is like mine, you'll see when you again carefully remove the circuit board, that the on/off button has cracked off of the piece that holds it. This is why the button remained stuck in one positon when it was depressed. Re-align it so that it is uniform to the other buttons and place a few small strips of cut electrical tape to hold it in place to the end where it broke off. Crazy glue or the like won't give the button the flexability it needs and will probably just crack again. What the tape (I layered 3 strips) will do, once the circuit board is scewed back, is allow the button to return to position after it's pushed. I just did this and so far, after a dozen on/offs it's still working. Good luck. Go have a beer.
  • Anonymous Apr 10, 2011
    Hey all. I found a very quick, if not permanent solution. Had the same problem and of course in the off position. I noticed that the icon on the button itself was not pointing straight up as it always did. I also noticed it didn't make the clicky sound when pushed. So I grabbed a little piece of paper tape and and stuck it to just the button and rotated the button so that it was pointing straight up and bamm, monitor started right up! Now I get a power strip ;)
dscarty
Level 1:
  • Contributor 2 Answers
  • Posted on Jan 10, 2010
dscarty
Contributor
Level 1:
Answers
Questions
0
Helped
31827
Points
19
Spin the power button so the line is at the top straight up and down. I was ready to disassemble my monitor and saw this tip on another site. Works like a charm. Stupid Dell.
  • 3 more comments
  • rercsr Sep 19, 2010
    Can't believe this was such an easy fix! Thank you so much!!
  • motivepower Feb 02, 2011
    SO far this has worked for me. Phenomenal.
  • Eivind Hagen Feb 08, 2011
    Yes, this worked on my 24" Dell monitor as well. Glad I didn't have to take the thing apart for such a silly problem.
  • Anonymous Jul 26, 2012
    Worked for me too, of course I didn't see this until I bought a new monitor, but now I have a spare!!
  • dscarty Sep 11, 2017
    If you put a piece of clear tape over the button after it's in the right position it won't spin any more.
Anonymous
Level 2:
Novelist:
  • Expert 231 Answers
  • Posted on Sep 05, 2007
Anonymous
Expert
Level 2:
Novelist:
Answers
231
Questions
0
Helped
271941
Points
307
Hi, my best advice is dont try it. Monitors are not easy to access and expensive to have repaired. A simple fix is to plug it direct into a switchable power outlet and just switch it on/off from there. Regards mistyman
Anonymous
Level 1:
  • Posted on Dec 22, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
30482
Points
10
If your on and off button does not work just take off the trim. You will find that the plastic button just broke off. Take the button out, put the trim back on with out the button and now you just need a pin to push the on buttom. That's it.
Anonymous
Level 1:
New Friend:
  • Posted on Aug 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
30482
Points
First of all if your monitor is stuck in the on position - you are lucky- do nothing- get a power strip. For those stuck in the off position, The Delli Lama does have the best solution - I just did it but wanted to amend with a couple of tips. Pulling the plastic frame up is not easy . There is metal around the screen and I had to work a small flat screw driver between the metal frame and the plastic to get the first amount of separation ( with a pop) - then worked my way around- just be careful not to touch the glass with the tool. Following delli's instructions I got the circuit board off and yes one of the three tabs on the button was broken. The button tabs are in the same place as the wheels of a tricycle. My front wheel tab was broken. Unfortunately that tab actually is what touches the board to turn it on. I then simply performed the buttonectomy described in #6 and removed it. Important - the actual power button on the circuit board is located just to the left of the power button hole, so sticking the eraser end of a pencil in only touched the light . The power button has a tab on the left which pushes the actual button-my tab was gone. I suggest plugging in the monitor while the board is accessible (don't touch anything) and pushing the button on the board to power it up - if it works pull out the power plug and re- assemble . Then when it is plugged in it should come on. Just use a power strip to turn off and on. I don't see how the original button can be made to work again and I also don't see any easy way to get to the real switch after re- assembly because it is hidden just to the left of the power button hole. Don't be afraid to try this , it did not take long and the only special tool is a small screw driver.
Anonymous
Level 1:
  • Posted on Oct 17, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
30482
Points
My problem was the power button broke in the off position. The best solution posted by Dellillama worked for me,with a slight modification. Rather than replace the power button, I simply left it out and used a pencil, eraser side, to push the real power button (which is on a small circuit board inside the plastic panel) on once I powered up the computer. And I leave it on rather than turn it on and off each time I use the computer. Rather than a gaping, green-lighted hole where the power button used to be, I covered it with black electrical tape...sort of a power button-ectomy.
The problem was that the power button was connected to the computer by three very thin plastic posts, and it had broken off of them. To say this is cheap construction is an understatement. The jokers at the technical help desk told me my only solution was to buy a new monitor. PS - My monitor was a 17 inch Dell 1704 FPTt.
Anonymous
Level 1:
  • Posted on Jan 10, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
31192
Points
10
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} I ran across this post after fixing mine. I did the same as Delli Liama.
Except I put a small dab of silicone sealant on the hinge part of the button. Then put a small piece of thin plastic over it so if I had to take it apart again the silicone would not stick to the PC board. Remember not to cover the whole button or the light will not work. This was about eight months ago and all is well
Calvin
Anonymous
Level 1:
  • Posted on May 02, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
30482
Points
My button somehow got stuck as well. I picked the plastic part of a button out with this cuticle nail picker thing I had in my drawer (yea for chicks fixing computer problems!) and then I simply used a push pin to return on my screen. Please note that the on off switch to the motherboard is actually a little to the left of the plastic button it presents...it is like Dell made it for safe keeping. I will use the suggestion to get a power strip to turn it off and on, yea for saving money.
Anonymous
Level 1:
New Friend:
  • Posted on Apr 10, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
30482
Points
Anonymous
Level 1:
New Friend:
  • Posted on Aug 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
30482
Points
I had same problem with my 2 Dell monitors and from then on, I only buy Samsungs or View Sonic
A
Anonymous
I have a flat screen Dell that I got from a friend. The power switch wouldn't work. I took it apart, which is easy, and found that the chip for the monitor controls, plus the on/off switch was broken off right at the end where the on switch is. Easy fix
llangrill
Level 1:
New Friend:
  • Posted on Feb 02, 2010
llangrill
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
30644
Points
5
There is a small, long circuit board held by three screws, under the switch push-buttons. The actual switches are metal spring domes that are depressed by the plastic pushbuttons to make contact under the dome. These metallic domes can be pressed by about anything, even a fingernail, to make contact. The power push button is bigger than the others and has the green LED under it to indicate power-on. This is the problem. The other, smaller switches have their metallic dome directly below them. But, the metallic dome under the power button is offset to the left (because the power LED is directly under the button) and the power button dome is pushed by an unfortunately thin tab stick off to the left of the power button. This fatigues and fails (the tab breaks) long before the other buttons might fail.
The fix we settled on was: taking off the plastic rim around the front of the monitor (it holds the plastic push-buttons) , prying it off and inch or so at a time. Then, unscrewing the small circuit board and drilling a hole next to the power push-button, directly over it's metallic spring dome switch. We then put in a small nylon screw, with the end inside the plastic, directly over the targeted metal dome. We screwed a nylon nut on the shank of the screw which sticks out of the monitor a little ways and cut the screw off beyond the nut. This gives a little somewhat floppy, plastic pushbutton for power, and the old power push button (still in place) still lights up when power is on.
Anonymous
Level 1:
  • Posted on Aug 11, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
30482
Points
Dell Demension 2400 monitor amber when i start computer the light turns green. Monitor screen starts to light up then goes dark.
on button still lit.
Anonymous
Level 1:
New Friend:
  • Posted on Feb 22, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
30482
Points
Generally, this method applies to the Dell W1900 LCD/TV monitor. Rather than some monitors or laptop screens which give access by prying off the front bezels or trim, the Dell W1900 gives access by removing the large black back cover. Here's how I did it:
Unplug. Remove the rather heavy stand. Remove six screws around the outside edge of the back cover. Remove four screws where the stand was attached on the back. Then gently pry off the rear cover with a flat head screw driver or wedge. Pry around the entire circumference a little at a time to gently unsnap and remove the back cover.
This gives access to the power button (and all the buttons for that matter). You should be able to see what is causing the mechanical problem- for me ...a broken plastic "wing" of the two rather flimsy wings that rebound the pushbutton power button.
Then pick the best solution:
1. fashion a new pushpin solution.
2. leave in "on" position and use remote control or a external on/off power strip to power monitor on/off.
3. apply pressure to the correct part of the power button..for me just one side of the flimsy plastic "rebounder" was broken. So I magic marked where to push for the best on/off direct push. (for me this was the top). This probably won't work if several people use the monitor.
4. Something better.
Anonymous
Level 1:
New Friend:
  • Posted on Jan 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
30482
Points
Yes I recognise these soltutions my
DELL E172FPb LCD Monitor
didnt work so I removed th epower button like #11 slovemina the power button-ectomy.
Anonymous
Level 1:
  • Posted on Dec 14, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
30482
Points
Answer to some of problems above 2 yr old Dell monitor just went out. We guessed the switch was bad after reading the above posts. I figured I was being green by turning off the monitor each time. Do not do this!! We used hints above and we 'fixed' it for now. Hubbie got the face plate off the front. Takes some doing. Un plug and disconnect monitor of course. Lay flat on it's back. using a thin screwdriver..pry off the front lip..working around the edge very carefully. But hey, we figured we had nothing to lose. be careful as the little circuit pad is attached. you have to carefully unscrew the circuit pad..my smaller hands worked here. We tried the tape thing..but it did not work..so I used a pencil eraser and it came right on. then more difficult...The hardest part...using the tiny screws to put the circuit pad back on. Needless to say..we are leaving it in the on position. We have a sticky over it to remind us.
So we had a $200+ monitor with less than 2 cents worth of plastic on the switch. It was so flimsy..paper thin. It is a wonder it worked at all.
So for your info...latest from Dell. At the time we bought.. monitor had only a 1 yr warranty...since we bought with a Computer. If you buy alone you have 3 yr warranty. Now I notice Dell is giving 2 Yr warranty on all? Ok..makes no sense.
A
Anonymous
There is a small tab on the side of the power button which makes contact with the switch and probably has broken off, if you push any of the other buttons on the monitor and they snap back they are working properly, I do not know if Dell offers a replacement trim for your monitor or not (which has the buttons made into it), I have the same problem and trying to find out if they even offer a replacement. You can remove the trim by removing the 4 screws from behind the stand and then carefully removing the trim.
Anonymous
Level 1:
  • Posted on Oct 31, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
30648
Points
My 24" Dell monitor won't turn on .. just happened today. Paid a lot of money for this monitor and it looks like a 10 cent on/off button is the problem...and I don't feel comfortable opening it as described below. I'll call Dell about it and see what they say, but if they say buy a new one just for a broken button, you can bet I'll buy a different brand. Dell is going down and no wonder.
Anonymous
Level 1:
  • Posted on Nov 02, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
30482
Points
0
I have a Dell Dimension 2400 computer. I purchased it used. The desktop on the monitor is blurry. How can you clear it up?
3 Related Answers
Anonymous
  • 3940 Answers
  • Posted on May 20, 2008
SOURCE: dual monitors on my dell dimension 2400
To run dual monitors will require you to install a PCI video card.
Like this one:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2484223&CatId=319
A
Anonymous
  • Posted on Sep 18, 2008
SOURCE: Dimension E510 LCD Monitor with broken power switch
Thanks for responding. Nothing happened when you pressed in the power button and the warranty had expired; Dell was no help so don't bother. I read that there were tab(s) on the plastic power button that had broken off and no longer engaged the power switch. I "solved" my monitor problem by drilling through the plastic case between the power button and the minus button, pulled out the plastic power button and pressed the switch with a flat screwdriver to turn on the monitor. Now I leave the power on all the time and put a piece of black masking tape over the space where the power button was. Not the best solution I'm sure, the hole isn't pretty, but it works. If anyone else wants to try this solution be careful when you drill through the plastic case because the switch you want to engage occupies the space between the buttons, exactly where you are drilling. If you drill through the switch you might as well throw the monitor into the recycle bin. I expected to find an actual button switch and was surprised to find a flat, 2 prong circuit switch instead. Good luck to all.
Matt
Anonymous
  • 6 Answers
  • Posted on Sep 23, 2008
SOURCE: Dell Dimension 2400 won't turn on
replace the fuse
Power button for monitor is broken
leighkavo, it would be easier and less of a hassle to purchase a new monitor than trying to replace the power button. You can do so, by going onto Ebay and seeing if there are parts for your particular model. Then you'll have to break open the casing on the monitor and replace the circuit board where the power button is housed.
What type of Monitor do you have? Here is a Dell example of replacing a Monitor Power Button. http://www.youtube.com/watch?v=RXAQxwCTuuI
Dell dimension 8400 won't turn on
Sounds like you might have a Bad Processor, Take it to a shop, don't tryh to fix this one yourself
Reinstalled Windows XP on an old computer (DELL Dimension 2400) and the monitor won't display above basic resolution. Downloaded and reinstalled the monitor driver and still no good. Opened up START
According to the Dell Support web site the Dell Dimension 2400 has a built in Intel 3D extreme graphics adapter, assuming you are using this and not a PCI graphics card.
Go to the Intel Download Centre and run their Intel Driver Update Utility which will automatically scan your system for updated drivers for any installed or integrated Intel devices.
If the Intel Utility identifies an updated driver for your graphics adapter then download and install that which should enable you to configure a higher resolution for your display.
Button on monitor (1907FP flat panel) will not turn on when pushed,
you have to bring this monitor to the store and fix it or you have to remove the button itself and push it with a pen or a pin.
My Dell dimension 2400 monitor doesn't work when connected to my tower. It appears that it's off when I connect it to the Dell Dimension 2400 tower, but when I connect the same monitor to another computer,...
Hi! For dell machines when u unplug the video cable/VGA from the tower while the system is on it will show monitor self test.If you are seeing a black box moving around the screen it means that monitor is ok.Check connection between monitor and tower.Make sure cables are securely plugged in.Check if the tower is ok. There is a possibility that your monitor is ok but the tower is not.check the power button (whats the color) if amber/orange, this means there is something wrong the the tower. If its blue or white it means its ok.Also check if you are going to hear one beep, it means system is booting up properly. If tower is ok and you are using a expansion video card then try to use internal one, normally its the vga port above the usbs.If you are going to use onboard video card make sure you enable it first in bios.If all things fail, contact your manufacturer, if the system is under warranty then they will send a tech to check the machine.hope this helps...
Dell Dimension 5150 Stuck In Pwer Safe Mode
Sounds like a problem with the video card. Cross check the connections to the CPU. If its all fine, Then Connect the monitor to a diffrenet pc and then use the monitors keys to change it to a plug and play mode.This might help with ur problem
Matt
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
