SOURCE: The Drum on my LG DLE2512W Dryer will not turn
no problem with motor or control board. fault is with the motor capacitor only. this is often attached to the motor or near it. the value of the capacitor will be printed on it (usually about 8uf) and you should be able to source from an electrical spares shop
SOURCE: LG DLE7177 Thermal fuse
Thermo Fuse is normally followed by the power source or on
the circuit board, Follow power source and you will find fuse.
SOURCE: My LG electric dryer DLE3777W takes forever to dry
Check to see if your vent is not kinked or clogged. Also, check if your lint screen is clean. If you don't clean it each time you loose 10% efficiency. Good Luck
Good Morning friend, thank you for your post!
From my understanding your Frigidaire dryer, LEQ1442ES1, will run and then shut down after three or four minutes. I would recommend a reset on your dryer which you can do by unplugging your power cord for roughly ten minutes.
If that does not correct the issue it sounds like a potential problem with your control panel or a sensor. I would suggest having a professional come out and repair your appliance to avoid any unnecessary part purchases. -Matt
