Remove carb from mower. Use carb cleaner and small acid brush to clean outside of carb. Remove bowl from bottom of carb. Clean bowl. Observe bolt that held carb bowl to carb, see if it has a hole or holes thru it. Clean out holes with bread wrapper wire with about 1in of wire. Test float, float down fuel flow, float up fuel stops. Use bread wrapper to clean center port of carb from bottom up thru carb body. Remove float pin float and meter needle, use bread wrapper to clean meter needle passage up thru carb body. Re-assemble carb.
Honda carbs can be purchased new for $14 - $27.
