Honda gv100 lawnmower blowing eng oil out of breather pipe intoairfilter resulting in excessive smoke from exhaust
I think that will find that the wire strainer has become blocked in your engine breather system. Unfortunately the engine breather for your engine is located under the flywheel, the flywheel will have to be removed with a puller as this is a taper fit on the engine crankshaft and usually a very tight fit ( especially if it has never been removed before ), once removed you will find a small cover held on with two 6mm bolts, remove the cover and you will see a wire stainer, wash this out, and if possible blow it through with compressed air until you can see through the wire strainer when you hold it up to the light, refit all parts and hopefully you will have many more years service from your lawnmower, I write this as I have a garden machinery repair business in Chedzoy, Somerset, England and have had a very similar problem with a customers lawnmower, best of luck and happy mowing.
