The VAIO VGN-T350 is a notebook computer designed and
distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit
that stores data, consists of many clusters of data that can be rewritten with
new data.
If you are looking for a memory capacity upgrade, or if your
old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the
use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other
peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive
chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in
place.
Gently lift the hard drive and its cage away from your
laptop and disconnect the data cord.
Remove the four screws located at the corners, and then
remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and
replace the screws.
Connect the data cord to your new hard drive and place your
new hard drive into its chamber.
Close the lid and replace the screw to complete the
operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you
an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity
drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H
VGN-SR410J/B
Testimonial: "I do thank you Brian for your effort... the real concern is compatability... regrettably, Sony does not provide any guidance as to determine wich drive could be suitable/compatible. You suggest a SATA drive whilst Toshiba MK6028GAL is a PATA drive with -of course- different connector. My concern is compatability of the drive, not to buy a good for nothing drive that would remain forgotten on a drawer... Again, many, many thanks for your effort!"
Depending on how much free space you have you might try an pata / adapter some are small whether or not there is enough space from your had drive to its connecting point im not sure ?http://www.ebay.com.au/itm/PATA-IDE-TO-S... might be worth a look
SOURCE: I can not find SATA
ok you just change "Boot Priority" option and select it as "Boot from DVD Driver" and save it. Now you can load xp or any other OS
SOURCE: Hi, Brand : Imation Model : Apollo M250 Capacity
Hi, The hard drive Apollo M250 does not have any locking mechanism. It only has backup software. If your computer does not detect the HDD, it only means that the HDD is already broken.
other than that you need to get a 1.8" PATA/ZIF drive. They are unfortunately pretty expensive for what you are getting, but they are also fairly plentiful on eBayhttp://www.ebay.com.au/itm/NEW-Dell-FNGD...
