FixYa has been fabulous in answering previous questions for me. YAY Fix Ya!
We have several new employees and I need to change our employee directory (i.e., press 1 for Joe, press 2 for Suzy . . . .).
Also, I need to change call forwarding so if an employee does not answer, the caller goes to their voice mail. Right now it rings back to reception.
Thank you for any help you can offer!
First thing, these new employees have the extensions of the old employees correct, otherwise more changes that what I gave you here will not work properly, example when you hear Press 1 it went to Joe, and Mary is where Joe used to be; that will work. But it Mary is where Steve used to be, pressing one will go where Joe was and not to Mary. Understand?
Ok, for the first part- changing the greeting in the Auto Attendant via CCR tree... you have to get into the ADMIN mailbox:
-> FEATURE 9 8 3
-> Password 1020000 (this is the default password, but can be changed)
-> OTHR
-> CCR
-> ADMIN
-> TREE 1 and press OK
-> CHNG
-> Path 0
-> REC then press PLAY to listen to the greeting, and ensure that is the one that you need to change
-> REC the new message
-> remember to SAVE! otherwise all is for not.
THIS MAY BE REQUIRED FOR OTHER TREES ex 2 or 3, listen too all trees and change if required... same steps to get into the trees and prompts.
The call forwarding to Voicemail: You need to know how to manuver around programming via the template on your phone:
-> press FEATURE 9 8 5 to get the DN of voicemail
-> FEATURE * * 2 6 6 3 4 4 (**CONFIG)
-> password: 2 6 6 3 4 4
->TERMINALS&SETS and Enter
-> type in extension that you want to change and Enter
-> next to CAPABILITIES and Enter
-> FWD NO ANSWER and Enter and put in the DN of the voicemail
-> hit NEXT and then RLS and voila, you are done!
Thank you! I haven't had time to try this yet . . . .
when calling in and if you hit the promt 123 you get a former employees voice for this function . How can I correct this?
Norma
