Emerson LC320EM8 32 in. LCD TV Logo
A
Anonymous Posted on Apr 10, 2017
I have an Emerson LC320EM8A tv. I am able to turn the tv on either by the remote or at the unit. After about 15 min, the tv changes changes the channel to Video1. I can change the channel back to regular network tv the first time. Then once it changes the channel to video again, the remote will not let me change the channel, nor at the unit. I have to turn the tv off. Turn it back on. Change the channel, for the unit to change on it own once again. I have replaced the batteries in the remote. Now I am trying to unplug the unit for 30 min to see what happens next. My question is. If there is not a quick fix at home.
Level 3:
Top Expert:
  • Emerson Master 76,851 Answers
  • Posted on Apr 11, 2017
Emerson Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14995034
Points
237762
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
5 Related Answers
Anonymous
  • 16 Answers
  • Posted on Oct 09, 2008
SOURCE: NEW EMERSON 20" LCD STERO TV/DVD- NOT WORKING
the flash was the fuse inside the set blowing it usually takes out one or two diodes in the power supply section but maybeyou got lucky and its only the fuse.
Anonymous
  • 16 Answers
SOURCE: Won't turn on
one of the inverter transformers has gone bad replace the bad one and the set will work fine ,there are 6 transformers in the 32".
Anonymous
  • 86 Answers
  • Posted on Feb 07, 2009
SOURCE: Need TV code for Emerson HDTV LC320EM8A
I was successful in finding codes on this site that were not listed in the manual:
Direct TV Remote Codes
Anonymous
  • 1077 Answers
  • Posted on Apr 01, 2009
SOURCE: power cut off and won't turn back on
The board you need to replace is the power supply board. The board# is BA71F0F01042. Your power supply board should have the same number on the lower right side of this board.
360211d.jpg The problem is the 6 Transformer Inverters that power up the LCD screen. If one blows out, the TV will go into protection mode like it's doing now. All the Funai TVs are having the same problem. Because, it uses the same parts.
The board is hard to find right now. Only three places I know of to find it.
Ebay,
Discount-Merchant.com,
and Shopjimmy.com
Sadly, nobody has them in stock.
I wish I had a extra board to sell you, because I know how to repair it. I have the schematics diagrams and part# for the pieces on the board.
If you ever come across a replacement board, let me know. I would like to buy your old board. Here's my e-mail, [email protected]
Anonymous
  • Posted on Apr 18, 2009
SOURCE: How do you hook up a Emerson EWL20S5B LCD TV with a PS3?
Why don't **** your own **** you **********.
What is the digital code used by this remote to operate functions of an Emerson LCD Model LC320EM8A
Universal remote codes for Emerson Brand TVs are: 0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
LC320EM8A 32" TV WON'T COME ON NOT BY REMOTE (NEW BATTS) NOT BY TOP POWER SWITCH. WORKED LAST NIGHT NOW NOTHING, TRIED THE ONE SUGGESTION IN MANUAL TO UNPLUG FOR 30 MINS TO RESET(?) ALL POWER CONNS...
Hi Wayne,
I'm glad your getting somewhere with your research. If you arent getting even a standby light, try checking the plug fuse and if this is ok, then the power supply board inside the tv is faulty. Could even be the power pcb fuse or dry capacitors (bulging tops on faulty ones). Hope this helps, and good luck :)
Emerson 37" HD LC320EM8A flashes on and off
this is 9 times out of ten a bad relay or power supply unit there might be a bad capcitor inside that is causing this shutdown, I would rule out the powersupply before the relay at this point. Good luck when i doubt please bring it in for repair its still a good tv to invest in.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Need TV code for Emerson HDTV LC320EM8A need code to program my direct tv remote
Rca Universal remote RCR311W
Try with the philips this method:
Manually turn on the tv or the device to be controlled.
Push and hold the code search button until the red lights stand.Now release the button push and release the tv button,then you got to push and release the on off button until the device turn off stop push and release the enter button.
You might need to push the on off button 1 to 150 times.
Good luck
2answers
TV Remote Code
you can get here
http://www.tivocommunity.com/tivo-vb/showthread.php?t=359205
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
