How are you obtaining the music that you play on the Samsung C3010? If you're recording the songs yourself, it sounds like you are recording one channel out of phase with the other. This phasing "effect" is how vocal eliminators work. Try playing back music from another source and see if the vocals return.
SOURCE: No vocals!
dude, is your earphones plugged all the way in?? i know it sounds stupid but sometimes that happens to me. if they are only half way in I only hear music not vocals. hope it helps
SOURCE: sound capabilities
The symptoms you describe are caused by a break in the earphone socket ground connection.
If you are confident enough, dismantle the player and re-solder the 4 connections to the earphone socket.
SOURCE: DISK ERROR WHEN I TRY TO USE MP3
Double check p. 17 of the manual for a firmware upgrade, in case this message is caused by a db corruption, but the error may also be caused if your player is in the "lock" or "hold" position.
Link to the only manual on Centon's low-budget website:
http://www.centon.com/documents/mp3guide.pdf
-Tha Mp3 Doctor
SOURCE: Songs Sound Distorted
Setup your device to the default settings, and format it, than copy a new music into the device and listen.
Hope this helps.
