Question about Toshiba Satellite A135-S4527 Notebook
Taskbar migration; missing battery icon
Taskbar has migrated to right side of screen (vertical) and won't drag back.
battery icon is missing from notification section of taskbar. can't find or restore it.
  • Henry W. Newell Apr 06, 2009
    regretably, i've procrastinated beyond the save-dates of restore points. will be wiser in the future, though. thanks.
    Scholar:
  • 38 Answers
You can try the following:
Click Start Button,
Then select All programs,
then "accessories",
then, "system tools",
then, "system restore",
A utility will start. click Next.
(Please note that it will not cause any harm to your data so dont worry about it.)
after flipping through couple of screens, it will give you an option to roll back the settings to an earlier time.
Select an earlier Bold date (that means a system check point exists) click on a check point and click next.
It will ask you to restart after reload. Allow that.
(The system will be rolled back to the point you selected (select a checkpoint that was earlier than the problem occured)).
you will see that once the system will restart, it has restored the system settings to an earlier time and your problems are resolved.
Will appreciate if you can rate this solution offered to you.
Thanks & Best Regards,
Techno-Geek.
Posted on Apr 06, 2009
SOURCE:
How to move icons from left side to bottom of screen
On all windows apart from Windows 8, you drag them from the desktop (left hand side) to the bottom (taskbar) with the mouse.
If the taskbar gets full up the icons might disappear.
The double bar at the end of the taskbar must be moved to the right for more of the taskbar to appear.
Mar 14, 2015 | Lenovo Computers & Internet
Tip
Get back the Quick Launch bar Windows 7's new taskbar functions as a program...
Get back the Quick Launch bar Windows 7's new taskbar functions as a program launcher as well as task switcher. As a result, the old Quick Launch bar, the area on the left side of the taskbar that contained shortcuts for frequently used programs, has been banished. However, if you really miss the little applet, you can add it back. Here's how to do it:
1. Right-click the taskbar and choose Toolbars --> New Toolbar.
2 . You'll be asked to select a folder for where the new toolbar should live. In the Folder text box at the bottom of the dialog box, enter this text:
%userprofile%\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch
After you do that, click Select Folder. A link for the Quick Launch bar will be added to the taskbar. It will be on the right of the taskbar, just to the left of the Notification area.
It's not particularly useful docked all the way to the right with no application icons showing, so we're going to have to do a bit of work on it to make it useful. Right-click the taskbar and, in the pop-up menu, remove the check next to "Lock the taskbar." Now right-click Quick Launch and remove the checks next to Show Text and Show Title.
Once you've done that, drag the vertical triple dotted line next to the Quick Launch bar to the left until you expose its icons. To prevent further changes, right-click the taskbar and check Lock the taskbar.
You can now use the Quick Launch bar as you could in Windows XP and Vista, including adding icons to it and deleting them.
on Jan 12, 2010 | Computers & Internet
I need screen on my pc back to full screen. and I cons back on bottom
I'm assuming you have windows 7. Right click your desktop and go resolution. Drag that bar up to the recommended. Now by the icons do you mean the taskbar? If so wherever it is click it and drag it back to the bottom. Then right and click it and go lock taskbar.
Sep 07, 2013 | HP Computers & Internet
The icons that were at the bottom Windows desktop have migrated to the LH side of the screen. How do I undo this?
If this is an xp, you need to first unlock the task bar. Right click on the task bar, click properties, and uncheck Lock The Task Bar. If it is already unchecked, all you need to do is drag the entire task bar back to where you want it by holding the left button, then release when the taskbar is where you want it to be.
Dec 18, 2009 | Acer Aspire 5630 Notebook
MY TASKBAR HAS MOVED TO TIGHT HAND SIDE OF SCREEN
You should be able to left click and drag it back to the bottom of the screen.
Sep 20, 2009 | Microsoft Windows Vista Home Premium with...
PCMover program missing configuration screens
Some programs are in ex : express, standart, silver, gold version. The low payed programs as express often do only allow to ex : copy all the things to the new computer, for getting more features you need to purchase to a higher versions.
Hope thats help :O)
Aug 01, 2009 | Computers & Internet
Windows XP taskbar has "relocated itself"
Right-click the taskbar and ensure it's not locked..
Then just click on the taskbar and drag it to the bottom of the screen..
But i didn't understood the iconzied windows thing.. omg
PS: Please rate this solution
Mar 11, 2009 | IBM Lenovo ThinkPad T60
Icon
right click on th taskbar and select lock the taskbar if there is a check next to it. then just click and drag it back to where ever you want it.
Feb 01, 2008 | Dell Dimension 4600 PC Desktop
After migration help
your drivers need to be updated
Dec 15, 2007 | Laplink Software PCmover for PC
Quickcam camera icon is missing?
Do you mean the desktop icon itself, or the taskbar icon?
If you just want the desktop icon back, navigate to "program files / logitech/ quickam" folder. Right click on the "quickcam" (it will have a pic of the eyeball camera). Click "create shortcut". Drag that shortcut icon to the desktop.
To make the the taskbar icon, make another shorcut, and drag it to the taskbar.
Oct 06, 2007 | Logitech QuickCam Pro 4000 Webcam
Toshiba Satellite A135-S4527 Notebook Logo
304 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
