You may have damaged the radio. Take your car to your Kia service center and get them to check it out. It may only need the radio code to activate your radio again.
CarGurus.cahttps://www.cargurus.ca > Cars > Discussion-t66999_d...
This speaker carries all the dash sounds such as seat belt warning, turn signals, reverse cross traffic, welcome sound, etc. 14 answers · 13 votes: Following. My daughter just told me her 2018 Kia Sportage is doing the same thing. Local ...
It sound like you have a loose ground on the radio mount. Pull the radio, you will have to remove most of the dash, and ensure that all of the screw in the radio mount, around the inside of the mount, aer tight.
Pull out your console (very carefully with a flathead screwdriver) it just pops off, and check your wire connections leading to your radio. you may take it out with a screwdirver and a bit of a yank but be careful, its really not that hard, it all just snaps into place, there are a lot of wires back there one may just be loose
SOUND LIKE BAD STARTER SOLENOID.IF YOU HEAR LIKE CLICKING NOISE.CHECK BATTERY CABLE FOR TIGHTNESS AND CLEAN FREE FROM CORROSSION.CHECK BATTERY VOLTAGE SHOULD BE 12.5 VOLTS.IF NOT BATTERY HAS WEAK CELL IN IT.IF YOU HAVE TO REPLACE BATTERY.TURN OFF RADIO BEFORE DISCONNECTING NEGATIVE BATTERY CABLE SO YOU WONT LOCK OUT RADIO CODE.
bottom rear of engine at bell housing of trans, u will need to jack the car up and put it on safety stands before starting work, also disconnect the battery, be3fore hand ake sure u have the radio code if one is required.
