Question about Mitsubishi WS-55819 55" Rear Projection Television
Mitsubishi WS 55819 55" Rear Projection TV. Was moved. Prior to moving it was fine... After we moved it upstairs without any significant jostling, the TV now is not working. at first after turning it the display was working, but the image was very skittish, jumping around, it has degraded to no image and now shuts off after a minute or so. I was able to extract a code 23, meaning horizontal deflection bad... I have the service manual, but I see no reference to troubleshooting that issue. I suspect there is a wire or connection loose. When we moved the TV upstairs, we carefully removed the front speaker cover, and the fresnel lense frame to protect it and provide better grip. We had to carefully roll the TV over a hand rail and onto its top and then slide the TV up the stairs to the top. It was not dropped or jostled at all. Just an hour before I had completed a convergence alignment and watched a video to confirm all was working fine.
    Top Expert:
  • Mitsubishi Master
  • 53,777 Answers
The roll over the rail is what killed it.
Posted on Mar 09, 2017
5 Suggested Answers
SOURCE:
techman
  • 3130 Answers
SOURCE: Convergence problem w/ red horizontal only-WS-65807
Do not try to adjust anything yet!! Adjustments do not get out of alighnment all of a suddenly. The convergence adjustments are there to do minor aging alighnments. I would first check for bad solder connections on the convergence IC's first.
Posted on Sep 09, 2007
yankeegurl
  • 121 Answers
SOURCE: Moving a WS 55511 downstairs in my house
the easiest way is 2 people carrying it but if you do have to slide it make sure you don't bump it cause if you do it will knock off the convergence
Posted on Apr 13, 2008
  • 927 Answers
SOURCE: mitsubishi ws-55315
Good Day;
More than likely your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV.
If after the fluid has been removed and TV still does not work, call an Authorized Service Center to come out and repair TV after giving you an Written Estimate. The boards are not available.
Always try resetting the TV by unplugging it for one minute then plug back into A/C outlet and ALWAYS UNPLUG TV BEFORE ATTEMPTING ANY REPAIR ON THE TV.
Good Luck, big IRISH.
Posted on Sep 19, 2008
SOURCE: Picture is completely out of alignment, went to do
i need part
Posted on Jan 26, 2010
Vertical Alignment
I would take a good look to make sure it got back together correctly, set does have a hidden adjustment menu once entered the Mitsubishi remote can adjust a lot of things including centering etc, want to be careful in that menu,,,confirm the model and I will give you the four digit enter code for the set.
Aug 27, 2012 | Mitsubishi WS-65315 65" Rear Projection...
Good morning, I am in the moving business and have a customer that wants me to move their large TV Mitsubishi medallion tv. She thinks is comes apart in two peices for easy moving and I need instructions...
If the model is a WS-65809 that sey doesnt come apart. Actually very few rear projection TVs can be seperated Some RCA TVs can be disassembled to several pieces. Also I would let customer know that because a CRT TV has three CRTs that are aligned to each other , Moving the TV will cause the convergence to be adjusted. Based on model it can be just pressing the auto convergence option with the remote, But older rear projection TVs (2003 and older) have been known to blow ICs after a move when trying to reset the convergence. The ICs weaken over age and they can blow anytime the convergence adjustment feature is used, so its always a good thing to let someone know that even if very careful when being moved there set may develop convergence issues after a move because its a 3 CRT rear projection TV
Sep 15, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65907 65 in. Rear Projection Television; No Sound from internal speakers. I don't believe external speaker will work either but I have no way to test. TV was move from one home to another....
first you need the original remote to do this, with the set on use the remote to enter the following (menu) 8,2,7,0 this will bring up the options menu the first thing in this list is "Inital" and should already be highlighted then simply press enter on the remote, this should reset the tv
Dec 22, 2009 | Mitsubishi WS-65907 65" Rear Projection...
I just moved my 42in. Toshiba rear projectiom Tv from my basement to the upstairs and now my convergence is off. The red tube cross is low on the manual adjustment and will not go up to the other colors.IT...
It sounds like you jostled the red CRT gun when you moved the set. If the convergence adjustment still moves the red cross hair the the circuitry is okay. Your red gun needs to be realigned. This requires a service call unless you want to attempt it yourself. It is fairly involved and requires some specific tools as well as using the service mode on the remote to reset the convergence after the gun is repositioned.
Dec 06, 2009 | Toshiba 53H71 53 in. Rear Projection...
My mitsubishi ws 55807 turns on alright but the blue, green and red color are on top of each other and makes every image look triple. This tv was a gift from a friend and we moved it a lot to take it...
You have a convergence problem, if it happened after you moved it around then its either broken solder joints around the convergence modules(stk392-110) or it is a physical problem.
You could take the front screen off and see if the mirror inside has shifted.Also take the front and rear covers and look inside for anything that might have moved or cracks near components mounted on heathsinks. hope this will help. Good luck
Dec 02, 2009 | Mitsubishi WS-55807 TV
My xbox360 Wont work on my WS-55513 MITSUBISHI COMPONENT
Try changing the settings on the Xbox under display to 1080i. If it is 1080 p, or 720p, the image will look funny so make sure it is at 1080i.
Your welcome
Your friend from down the lane!
May 21, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Do you have friends? If so, call them and get help.
Apr 12, 2008 | Mitsubishi WS-55511 55" Rear Projection...
The best ways to move my 55 inch Mitsubishi TV to another home?
Move it with an appliance hand truck and do not lay it on it's side. When transporting, always keep unit standing upright. Good Luck
Aug 14, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS55809 "red" converge problem
Proper description is convergence IC ...part # STK392-570...
there are two in model # WS 55809...replace both.......T.
Jul 30, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55819 55" Rear Projection Television Logo
67 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
