SOURCE: The cd tray on my compaq presario desktop wont close
The drive should be replaced. they are fairly cheap (like under 50 bucks) and simple to install. sorry about your untimely issue
please rate
SOURCE: My usb keeps sayin power surge on hub ports
You may need to upgrade to a higher wattage power supply, which would also help with the performance of your computer. Or try updating either your system bios or USB drivers.
SOURCE: My Compaq Presario SR1103wm doesn't have cd-rom
If your not familiar with the insides of your cpu. You can purchase an external cd/dvd/rw drive and hook it up. usually with a usb or supplied cable. To install depending on type and brand just follow the instruction that come with it. They do work very well.
SOURCE: The screen on
make sure there is no floppy disk in the floppy drive...if not this means your hard drive is not being seen or hard drive has crashed. If that is the case, find a local reputable repair place...Call HP (owns Compaq brand) for a local authorized service center.
SOURCE: looking where i can find
Telephone HP, and order a set of the "System Restore" CD-ROM disks.
Probably about $20, plus $20 for overnight-courier delivery.
Testimonial: "great and fast reply thanks a lot "
