I have connected the turntable to the computer& to the mains.When I click on next I get a message Unable to connect to audio device.Please make sure your device is connected &switched on.
I have carried out the instructions on the pink sheet for windows XP.
This is the first time I have tried to use the programme although the turntable has worked perfectly well connected to my HiFi Centre.
SOURCE: I have purchased a turntable with ez audio
You can record the entire album, both sides without having to press next. When the entire album has been recorded then press next, you will a dialog box that allows you to name the album and songs. Make sure you have the most up to date software from the ION website- that is if you have an ION turntable. Go to ION website and locate your turntable- software will be on that page. Run it and it should correct any problems.
SOURCE: turntable drive assignment
Windows?
Open control panel
Administrative tools
Computer management
Disk management
See if you see your turntable, If you do you can right click your mouse and select change drive letter, Change it to one you are not using and you should be back on track.
If this is not it then post more about what you are seeing.
SOURCE: ionusb turntable not connecting to computer
its a driver issue. try to connect it to another unit that is using another os, or check manufacturer site for driver support
SOURCE: No sound after multiple attempts. No sound levels changing
several people are having this trouble but most seem to work ok .. the unit has its own built in preamp and digital interface so, in this case, you dont have to worry about what cartridge it has .. in fact you can hook its rca outputs to the aux of an amplifier (not the phono input) .. or you can connect them to your amplified computer speakers thru an RCA sterio to 1/8 inch jack adapter ... i am working on a solution remotely since i dont have the unit yet ... but here is a suggestion (for xp) .. find the volume icon in the bottom right task bar .. double click on that .. that should bring up a box with several volume controls .. make sure none have "mute" checkmarked .. turn up all the controls so you cant miss anything if it comes thru ..try the table ... now click on "options" in that volume control box then "properties" then put a dot for "recording" .. select all of the volume controls in the bottom box .. now click ok .. that will give you some level controls for recording . turn them up ..then select them one at a time to see if any work (with table playing) .. if none of that works then there is likely an incompatability .. you might look for upgraded drivers for your audio card .. .. i will likely have more on this as i remotely get one working or if i can find one to play with .. maybe a few days .. some audio cards turn off sound outputs when you are in the record mode .. thats so you dont get screeching thru the mic input .. but there is usually a way to defeat that .. the units software should have done that for you .. i have found some popular laptops that horrably dont have sterio inputs (only monoral for the mic input) ... on a few that can be fixed with special software but on others (like my inspiron 6000) there is no hope ... i purchased an audio input adapter that connects to the USB port .. that gives you several analog inputs that are sterio .. your turn table's digital output doesnt need analog inputs so you are ok unless you want to use the RCA jacks as audio input ..
