SOURCE: AELFCHECK Problem with Panasonic DVD Recorder
Hi
This problem is associated with a regulator on the power board. It's an easy fix if you can use a soldering iron.
If not you may be able to get someone to repair it for you. I have posted instructions on how to replace the defective component.
Please note the instructions I have given refer to the DMR E55 but the E95H is much the same.
To see my earlier posting, please Click >HERE<
SOURCE: Panasonic DMR-E85 DVD recorder TV Guide problem
Try unplugging the DMR-E85 power cord. It is important that you unplug it from the back of the recorder, not the wall. Leave it unplugged for 10 or 15 minutes. For good measure disconnect the cable 'in' connection as well. Once both lines are plugged back in it will go through its self-check diagnostics. Leave it alone for awhile (give it time to consider the error of it's ways). If you are lucky, when you turn it back on it will ask you to verify the channel lineup. If this does work, and all the channel info is correct, press 'enter' (lineup 1 highlighted). Good luck! This is an awesome machine, WHEN IT WORKS!
SOURCE: PANASONIC DVD RECORDER DMR-E85HP
My Panasonic DMR-E85H also had the frozen "Please Wait" problem.I found this site and followed the instructions regarding replacement of the C1270 and C1271 capacitors with Radio Shack 1000uF 35V radial-lead capacitors (model 272-1032) @ $1.59 each. Took about 30 minutes plus the time to get the parts. Keep in mind that my husband and I have never done anything like this before. We followed all the posted instructions and the our Panasonic DMR-E85H works great now. Many thanks to everyone who posted these solutions and especially RandyChev for the great pictures. - What a life saver.
SOURCE: Panasonic DMR ES15 remote stopped working with dvd/recorder...
Try holding enter button and 1 together on the r/c for at least 3 secs
SOURCE: Unable to view/record cable channels with Panasonic DMR EZ48V
Here is what you will need. This is assuming you do not have a HD cable box.
1) A two port cable splitter available at your local hardware or electronics store. VERY IMPORTANT- this splitter needs to pass up to 1000 mghz so you do not interfere with the functions of the cable box. Also, when purchasing this don't be fooled gold does not always equal good (a common mistake made by folks).
2) 1 small coax cable.
3) 3 Additional coax cables. (1 long enough to reach from the wall to the cable box. 1 long enough to reach from cable box to the TV. 1 long enough to reach from wall to the VCR. These cables should be RG6 coax cable (about the width of a standard wooden pencil)
4) 2 RCA cables (Yellow/Red/White)
Here is how you need to connect the cables....
1) Use the small coax cable and connect it from the WALL to the INPUT of the two way SPLITTER.
2) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the CABLE BOX.
3) Use one of the coax cables and connect it to the OUTPUT of the CABLE BOX to the INPUT of the TV.
4) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the VCR.
5) Use one of the RCA cables and connect to the DVD/VHS COMMON OUT on the VCR. Connect the other end of this cable to the VIDEO IN on the back of the TV.
6) Use the other RCA cable and connect it to the VIDEO OUT on the back of the CABLE BOX. Connect the other end to the IN 1 on the back of the VCR.
Here is how to set up the VCR-
1) Tune the TV to the video input that you connected the VCR to.
2) Go to the auto program in the menus for the VCR and select "CABLE" as the source and you should now be able to get all the channels you would normally get without the cable box.
3) This will give you the option to record shows from basic cable on the VCR. While copying these channels you will still be able to tune the TV to CH 3 for the cable box and watch TV normally through the cable box.
4) If you want to copy one of the channels that is only available with the cable box you will still be limited to only being able to watch that channel while it is recording but here is how you will do it.
Hope this has been helpful....
Good Luck....
