Sorry to be the bearer of bad news,but what your describing sounds exactly what a bad motor will do...run whiles is realitivly cool,cut off when hot the restart after a cool down period and run for a while till hot again.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Sounds like your coil pack is going bad. When they start to go bad, they will fail when they get hot but when they eventually cool down the car will run as normal. I would replace your coil and that should take care of your problem. Thanks for using FixYa!
Don't rule out fuel pump. Had a 95 do the same, ran great when cool in morning then when it got hot in afternoon, it would quit. Wait 15-20 minutes & go again, sometimes got me home, other times a few more miles until it cooled down again. Luckily I had access to a fuel pressure gauge. Cool in morning had 49 psi, when it quit, 2 psi. Wait 20 minutes, 49 psi again. If you can drive it around until it starts to act up then run into a repair shop for fuel pressure test it will confirm it. If not, they may need it all day to monitor the fuel pressure & confirm it is pump. If your a gambler, change it & fuel filter. One thing I did get was trouble codes indicating a lean mixture, due to starving for fuel. Have you cycled your key to retrieve any codes yet?
