SOURCE: 97 chevy suburban wont start
try putting a dab of solder on each one of the contacts on the fuel pump relay. i had a similiar situation where the relay contacts in the fuse box got strectched out over time so i put a dab of solder on each terminal to beef the contacts up and it worked perfectly. i think this will work because if the mechanic put a wire jumper in the contacts then electrical it is fine.
SOURCE: 6.5 turbo diesel wont start
check the high pressure oil switch next to the glow plug controller. if the switch is bad you will not get any fuel to your injector pump. unplug the molex and jump it out. this will bypass the switch. if it runs, just buy another high pressure oil switch. good luck!
