RTO Weighmax W-L396 Body Fat Scale Logo
A
Anonymous Posted on Aug 13, 2013
User manual Weighmax L396 - RTO Weighmax W-L396 Body Fat Scale
WeighMax W-EX650C pocket scales. When I turn them on reads "ERR" then shuts off. How do I fix them please?
Question edited for clarity and add maker.
The most likely reason is it needs new batteries. The secondary reason would be bad connection inside. A final answer is putting it on a surface that is not flat and stable coupled with a non-distinct switch on.
https://www.google.com/search?q=WeighMax+W-EX650C+reads+ERR
How do I remove the batteries to replace them?
Hello, Joanne -
WeighMax manufactures more than one model of bathroom scale. See:
http://www.weighmax.com/products/bathroom-scales-1.html
Not all the WeighMax bathroom scales take the same kind of battery. If your scale is one of them listed on the web page cited above, click or tap on the link for the information on the scale and look for the information on Power to find out the kind of batteries needed.
I do not find any instructions for where to find the battery compartment on any WeighMax bathroom scale. Therefore, I suggest you contact WeighMax Technical Support and ask. You will probably need to provide the model number of your bathroom scale. This is the link to the WeighMax Contact Us web page:
http://www.weighmax.com/contacts
Best wishes.
Digital scales weigh half of accurate weight
Recalibrate. If that does not take, then there is an issue with the scale. Try installing a new battery since a bad or weak one often results in erroneous readings.
Have a WeighMax postal scale..how to I cange from kg to pounds?
I had mine set to ozs for over a year and then it changed to kg. Couldn't reset it by hitting the button, so I removed the battery and then put it back in. It reset it to ozs.
I need WeighMax Pozo 35 Instructions
This scale perfectly fits my needs. It takes up very little space on a side table, and has held up great weighing the 5-10 packages I mail per week. I have found it to be perfectly accurate and would recommend it to someone else planning on using a scale with the same frequency as me!
Top RTO Health & Beauty Experts
Rob Hill
Rob Hill
Thomas Perkins
Thomas Perkins
Harsal Patel
Harsal Patel
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
