I am setting up HO trains using new Bachmann ez track. I am using an older non-modular transformer. Do I connect the turnouts to AC or DC on the transformer?
Bachmann IndustriesINPUT: 120 VAC 60Hz. OUTPUT: AC 16V 1000mA ... After the track connections are complete, plug the Wall Pack Power Supply into a standard 110 ... If your Control Center does not power up as shown here, disconnect it from the Wall Pack ...
Bachmann IndustriesNOT RECOMMENDED FOR CHILDREN UNDER 14 YEARS OF AGE. ... The E-Z Command® 5 Amp Power Booster provides extra power to the track so ... locomotives on our N, HO, OO, S, O, On30, or Large Scale layout. ... Make sure the smaller plug end is connected to the DCC input jack marked DCC IN (figure 2) on the.
the transformer shave a knob that makes the train go and go faster as you turn it
some have the knob in a central position so that one way is forward and faster or the other way is reverse and faster
accessories is for boom gates , lights , anything else that you have set up to operate besides the train
get a meeter and check the volts on the line both ways,,,there DC volts both should read the same near as can be,,,,if volts are the same both ways on the lines,,, its the trains motor,,,,
Had the same problem. The loco would buzz, but no movement. Took the loco & controller to my local hobby shop for testing. Found out my loco was fine, but the controller had shorted out. Swapped it out & it's all good.
