You will have to hold the flywheel for removing the clutch. It may require removing the blower housing.
I use an impact wrench which loosens the bolt w/o holding the flywheel.
It's 99% a regular bolt (turn ccw to remove) since left hand threads cost more to buy the bolt and tap the hole and small engine stuff is made as cheaply as possible.
SOURCE: JD LX173, Kohler Command OHV Engine keeps droping mounting bolt
Use a thread locking compound on the bolts - and torque them to the correct spec.
This will prevent them shaking out.
