Lands Phones Logo
A
Anonymous Posted on Aug 13, 2013
Reset after power outage - Nortel Lands Phones
Brief power outage. Light timer not working.
If there was a brief power outage and your light timer is not working, there are a few steps you can take to troubleshoot the issue:
  1. Check the timer settings: Make sure that the timer is set correctly and that the time and program settings are accurate. If the timer has lost power, it may have reset and will need to be reprogrammed.
  2. Check the power source: Ensure that the timer is receiving power by checking the outlet or circuit breaker that it is plugged into. If the outlet or breaker has tripped, reset it and try again.
  3. Check the timer battery: If your timer has a battery backup, check the battery to make sure it is still functional. If the battery has died, replace it with a new one.
  4. Reset the timer: If none of the above steps have worked, try resetting the timer to its default settings. Refer to the user manual for instructions on how to reset the timer.
If the above steps do not resolve the issue, it's possible that the timer has been damaged due to the power outage. In this case, you may need to replace the timer or seek the assistance of an electrician to diagnose and repair the problem.
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
some of these had resets others reset after you unplug it for about 20 minutes and replug it in. some older models you had to hold in the power button for 5 to 10 seconds.
1helpful
Most programmable thermostats have batteries to keep the program from being lost in a power outage. If you thermostat has dead batteries or no batteries a power outage will cause the thermostat to revert to a default setting and it will have to be reprogrammed. Hope this helps.
Limit switch will not reset automaticly after power outage. no heat just fan with power comes back on.
The limit switch and the power outage should not be related. However if the switch is not reseting after a 30 degree drop it should be replaced.
Sound quality has diminished after power outage
Tries unplug,replug an hour later,let the tv reset itself back to factory setting.After,turn on the tv,go to the menu,go to sound on ur menu go down to reset the sound.The functions should go back to normal,not than.Ur tv Tuner signal board have a short,in the power outage occurance.
Can not reset after power outage
If display is on and you cant reset, the board has been damaged during the power outage. The current shoots up over the safe limit and does the damage. need to replace board and put a surge plug on line
After power outage I Can't connect without bypassing router
If you can connect directly then, the problem is the wrt54g router. Possible problems:
1) Power Outage damaged the router
2) Power Outage reseted the router
For the second scenario, you should got to the browser and type: http://192.168.1.1/ and check whether you can enter or not. If not, you need to configure the gateway IP on your PC to 192.168.1.1
Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
Top Nortel Lands Phones Experts
vince
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
