Orient Automatic Sapphire World Timer CEY04001B Watch for Men Logo
Posted on Apr 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i adjust date and time
I have problems with where and how to set date and time on my orient role style wach
Anonymous
Level 3:
President:
  • Master 1,197 Answers
  • Posted on Apr 06, 2009
Anonymous
Master
Level 3:
President:
Answers
1197
Questions
Helped
414309
Points
4380
The knob at the side....
  • First pull which will change the date.
  • Second pull which will set the time.
thank you
tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 • Watches
tip
on Jul 09, 2010 • Watches
How does its year calendar work?
The day at a glance calendar system used in this Orient watch, has been used in a number of watches over the past 40 years, perhaps most famously in the Wittnauer "2000" watch (which Orient actually made for Wittnauer under contract). Orient itself has used this system in a number of different styles of watches. Note that the daily date window is separate from the day of the week / month at a glance system; the date window is driven in traditional fashion by the movement.
The day/month at a glance system is based on a single disc inside the watch that is manually advanced by the user. If you look at the top of the watch, where the months are listed, you'll see little two-digit numbers. These represent different years--"04" refers to 2004, "11" to 2011, etc. To get the right days of the week at the bottom of the dial, you move the appropriate year under the current month. That will line up the days of the week--Monday, Tuesday, etc.--with their correct dates. You may see the same year repeated more than once on the upper part of the dial because the calendar has a specific pattern that can be replicated.
On older watches using this same system, the top pusher was used to adjust the date window, and a separate winding knob controlled movement of the year/monthly calendar disc. On this specific watch, which I have not handled in person, I cannot see a separate crown to adjust the date, and so I am guessing that you would pull out the set stem part-way to engage the disk setting mode. This would make sense because unlike the date window, where the date is always advanced, the year must move both backwards and forwards to align with all the months in a given year--you'll see that January and October are in the same place on the dial, for example.
If you're interested, here's an example of a vintage Orient that uses this same system for its calendar. Note how the monthly calendar and year/month alignment are flipped from the watch you asked about. Please note that I have no connection with this web site, make no endorsement as to the price being asked for this watch--but it has a nice picture of a classic Orient:
http://forums.watchuseek.com/f30/$128-all-steel-orient-perpetual-calendar-xl-case-vintage-watch-526811.html
On a final note, you'll see a number of people refer to these as "perpetual calendar" watches. That's not accurate. The year / days of the week disc holds about 20 years of calendar information. After that, the disc is no longer accurate, though you can easily keep aligning the monthly calendar just be referring to a printed calendar and adjusting it that way. For a period of time (not sure if they still do it), Orient would accept older watches with this system and change out the old year/day wheel with a new one that went further into the future.
My DZ4067 functions in the non-English day of the week for 21 hours a day now. How do I change it back so the the day of the week is in English for 21 hours a day?
The "day of the week" wheel on your watch actually has 2 settings on it--one for English, one for another language (often French, but could also be Russian, Japanese, Korean, or any other language, depending on the intended distribution of the watch). You'll need to shift the day track over by "half a notch," so to speak, to get things back in alignment.
The crown you use to set your watch can be pulled out into 2 positions. If you pull it all the way out, you set the time. If you pull it half-way out, you can set the day and date. If you turn the crown clockwise, you advance the date. If you turn the crown counter-clockwise, you should be able to change the day of the week. However, instead of turning the day back a full day, stop when you get a day with the correct language on it. At this point, pull the crown out all the way and manually advance the time 12 or 24 hours until the day and date advance as they would when the watch is running. This is to check that you've correctly gotten the day track correctly oriented. You may have to repeat this process a second time to get it right.
Once you have the day back on track, adjust the date and time, and you should be good to go.
Diesel's own directions, which can be found here: http://store.dieseltimeframes.com/common/images/customercare/instructions/ENGLISH/Diesel_Core-Inst_ENG.pdf are pretty cryptic, but they do have a diagram that might help a little bit. You'll want to look at the section for "Day/Date Watch IS02, 507.2-3, 517.2, 2105, 2305, 2405"
7helpful
I have bought a couple of lupo watches but there are no instructions so I dont know how to set them to the correct time can you help
This LUPO anion watch emits negative ions and infrared which make you calm. It soothes and relaxes your mind. How to set the time and date: This unique watch can display month, date, time & minute. 1.Press A button twice. (Date and Time displays when press once) 2.When the month figure appears, press M to set the month. 3.Press A button once again, the date figure appears and press M to adjust the date. 4. Press A button once again, the hour figure appears and press M to set the time. 5.Press A button once again, the minute figure appears and press M to set the minute. When you adjust one of among the month, date, time, minutes, just keep press A button until the desired figure appears and press M to adjust. Press M to see the date. Generally A button is to select the function. (Month, Date, Time, Minute) M button is to adjust the function.
Dec 09, 2010 • Watches
1helpful
How do I set the time on this watch?
Hi, function SOswitchMenu() {var el = document.getElementById('bodyDiv');if ( el.style.display != "none" ) { el.style.display = 'none';}else { el.style.display = '';}var el2 = document.getElementById('h2');if ( el2.className == "calHeader goog-zippy-expanded normalText" ) { el2.className = "calHeader goog-zippy-collapsed normalText";return;}if ( el2.className == "calHeader goog-zippy-collapsed normalText" ) { el2.className = "calHeader goog-zippy-expanded normalText";return;}} function SOframeReload() {var f = document.getElementById('soFrame');f.src = f.src;}
I had a watch similar, and it's actually very easy to adjust as soon as you have the solution, so:
You need a very thin stick (maybe a toothstick or a think pencil). 1) Stick it into the upper pinhole (on the right side on the watch). Then it starts to blink. 2) Adjust by pressing the lowest pinhole 3) Confirm with the upper pinhole 4) Now you'll go through each step (hour, minute, date, 24/12h, etc.) 5) Finally you will se the time on the watch (not blinking), If you press the lowest pinhole you can choose between: - static screen showing time - static screen showing date - shifting screen showing both time and date
Br. M
Tag wk 1113-0
The crown is probably a screw down style. The screw down stem is designed to keep the water out and should be screwed shut when not adjusting the watch. Look at the watch stem from the side, look from the 3 oclock to the 9 oclock, you should see the end of the stem. Now turn the stem counterclockwise. After a number of turns, the stem should pop out a bit, it is now ready to set. Most waterproof automatic day/date watches have 4 positions for the stem:
1: screwed down (locked)
2: unscrewed position A
3: unscrewed position B (stem pulled out to first "click")
4: unscrewed position C (stem pulled out all the way.)
Position A:
This is usually used to wind the watch, although some automatic watches cannot be wound by the stem.
Position B:
Used to set day/date. Turning the stem one direction will advance the day and turning it the other direction will advance the date.
Position C:
Used to set the time. Some watches will "hack," a term used to describe the ability to stop the second hand for accuracy purposes.
Be sure the watch is at least a little bit wound before starting theis procedure or it will not run when you get it set!
Unscrew the stem and pull it all the way out to position C. Now turn the stem to advance the time clockwise. Continue turning until the day/date advances, now you know you are in the AM 12 hrs of the day. It is important not to advance the day/date with the stem during the 3 hours before and the 3 hours after midnight, so go ahead and move the time to 8 am.
Now push the stem in sligthly until you are in position B. Sometimes it is easier to go to position A, the out to position B. Once in position B, advance the day/date until it is set for the current day/date.
Pull the stem out to position C. Adjust the time to one minute past the current time. Watch your reference timepiece until it matches your watch and push the stem in when they match.
Your watch is now set! Screw the crown down and wear it in good health.
Hacking. If you stop the second hand at 0 seconds, and wait for your reference timepiece to reach 0 seconds also, you can set the watch to within a second accuracy.
Movement slop. If you advance the time past the time you wish to set your watch and then "backup" to your chosen time, you will remove the slop from the geartrain and make your watch set more accuretly
2helpful
3answers
Date setting on Citizen 0510 chronograph
Try this method. Set the date until it reads a couple of days in the past and then set the correct time. Of course do not touch your date or time settings between the hours of 9PM-1AM. Wait until the next day, then move the hour hand forward until you reach the current date with the correct time.
Top Orient Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
Ngoro
Are you an Orient Watch Expert? Answer questions, earn points and help others
