SOURCE: Linksys WRT150N
I only have 3 suggestions.
1st one is to make sure the ssid is not similar to other routers you are using on your profile. ie.(change it to a unique name)
2nd is to make sure you check the box that says broadcast your ssid.
3rd check to make sure you select the router as an access point and not adhoc or infrastructure option. Finally you can try to change the channels eg. i like channel 3 b/c it doesnt interfere with any phone lines.
good luck
smeags.
SOURCE: Nice link for linksys routers.
It is ALWAYS best to use the products Main page for firmware updates.
For linksys:
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C1&childpagename=US%2FLayout&cid=1166859837314&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=3731486492B45&displaypage=download
SOURCE: linking cctv cameras over linksys router, ports
What is the problem exactly ?
For port list try this link :
http://linksysfirmwares.googlepages.com/portslist
Hope it helps
SOURCE: Linksys wireless connection to xbox 360
Goto your computer and click on start, the goto run, then type in ipconfig at the command prompt.
Write down the GATEWAY ip address as this is the Linksys router ip.
Now open up Internet explorer and type in the GATEWAY ip that you just wrote down.
You will be prompted with a username and pw screen/box. Factory default username is admin with pw is just blank(not the word blank but just nothing entered as the pw), or admin as the pw.
If you're lucky you should be able to manually configure the router without the config cd. If not, I have had this issue before and you will have to contact linksys for a replcement CD as some routers do require install cd since manual setup just doesn't work for some reason.
SOURCE: New computer with Vista operating system
You should not need the cd - if you connect the Router to your PC with an ethernet cable then you can access your router to setup the wireless configuration. You can find all the necessary downloads & upgrades for your Router, together with Installation guides etc.here:
http://www.linksysbycisco.com/US/en/support/WRT54GX2/download
