Yamaha 12V Air Pump Logo
Posted on Apr 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just purchased a used 2001 Yamaha XL800 waverunner
I just purchased a used 2001 Yamaha XL800 wave runner PWC, it has 157 hours. I was just (friend) told it has electronically controlled guillotine values in the exhaust system and they need to be cleaned or replaced around 150 hrs of use, is this true? Only have started the unit up with no experience in the water yet, so I can't tell if there is a real power issue??? IIf cleaning is needed at 150 hours is there another option such as an additive to help clean the system rather than removal of guillotine values? Does the XL800 rteally have guillotine valves in the exhaust system? PWC newbee.
Bob G
Level 2:
Habit-Forming:
  • Expert 104 Answers
  • Posted on Sep 23, 2009
 Bob G
Expert
Level 2:
Habit-Forming:
Answers
104
Questions
Helped
70627
Points
219
Yes. Those are called power valves. The purpose of those valves is they create a variable height on the exhaust ports. This is desirable because it gives you good low RPM power by keeping the height of the exhaust port low, and as the revs of the engine build, the exhaust valves raise up which opens the exhaust port up and allows the engine to create more peak HP due to the higher exhaust port and larger area of the exhaust port.
There is no additive that will clean your power valves. They have to come out.
2 Related Answers
Anonymous
  • Posted on Aug 23, 2009
SOURCE: excessive smoke coming from waverunner exhaust
is their a trick to putting on exhaust 1998 waverunner xl 1200?
Anonymous
  • 207 Answers
  • Posted on Jul 08, 2009
SOURCE: how do we start a yamaha 1998 xl 1200 wave runner
first put a new battery in it. then put your lanyard in the handle bar clip push the start button make sure that you have a life jacket on when your in the water and make sure that u attach the lanyard to your wrist or life jacket
2answers
What is wrong with my wave runner
Make sure you are using Yamaha oil not an off brand. It does make a difference.
1helpful
2answers
How to fix a water port?
possible seized water pump
the one that is not working
follow it back to the source look for blockages
but personally i cannot see a blockage stopping all water coming out
so i would look more at the water pump
What is the size and year model of my yamaha waverunner the hull id # yama31321394
Yamaha did not make the GP model until 97 and if the numbers you posted are correct you have a 94, that being said all yamahas up until 93 were either a 500 or a 650 so im guessing its not a superjet which is a standup so you may have a waverunner 3, Raider, Blaster, or a wave runner LX. What colors are on it? does it have twin carbs? there will also be a sticker on the engine cases noting engine size.
2004 waverunner fx cruiser, ran great last time out. Now hard to start and wont run on high speed. Nothing over 6 mph.
How old is the fuel? Ethanol causes major problems if left too long. You may need to empty the fuel and clean out the fuel system. Try changing the fuel filter and adding some seafoam to the fuel and running seafoam thru the fuel system. Hopoe this helps.
My 95 yamaha waverunner 3 will crank but won't stay ctanked what's going on?
check connections clean and no breaks in wires , check solinoid and starter in good order !
3helpful
Manual for wave runner 1991 WR650P LX
http://www.boats.net/parts/search/Yamaha/Waverunner/1991/WR650P%20WaveRunner%20LX/JET%20UNIT/parts.html. I hope this link helps, this should tell you all you need to know. Thanks for using fixya, mike
2helpful
2answers
Excessive smoke coming from waverunner exhaust
Top Yamaha Water Sport Experts
Bob G
ADMIN Eric
ADMIN Eric
johnny bonacci
johnny bonacci
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
