SOURCE: Honda EM 2500 Generator
I posted a general tutorial on troubleshooting this problem here.
Rate me?
Carl
SOURCE: honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
SOURCE: I have a Honda generator model EM3500X with auto
The control board that senses load (current) is not working.It should drop to low with no output current. (nothing running)
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: My Coleman Powermate 6250 generator has no power
Take the cover off and flash the rotor again with a 12 volt battery. Positive lead goes to the top or right side brush. Negative to the other brush. Just touch it on, then remove it, and check for power at plugs.
If that doesn't do it, change the AVR (voltage regulator)
SOURCE: Lombardini diesel generator starts and runs fine but no elecpower
remove the covering panel and expose the internals , check for loose/disscontected push on ( lucar ) connectors , if these are fine it is most likely the excitation capacitor is deffective , replace with exactly the same value/voltage rating/duty cycle . the capacitor is usual 1 or up to 3 cylindrical tubes with 2 wires comming from them , always take a note of exactly what wires you have taken off :) hope this helps
