Try pulling the fuse to the ECU from the dash for about 10 seconds to reset to default.
Turn the key to the run possition and pull the ECU fuse on the left side of the dash, reinstall the fuse and start the truck. It may stall out soon as it starts but don't give it any gas and let it stall.
Restart the truck and it should run after the second start and go for a drive, that should bring the truck back to factory default and need to lean everything again by taking all tine information from all the sensor's.
Try going back for the E Test after everything has been warmed up. Good luck.
Yes I think that is good advice. The mechanic went on vacation, and since I paid money already, I will wait to see if the codes have reset, if not, I will follow your advice and let you know.
Thank you very much! .
