Question about Lanier Office Equipment & Supplies
Lanier 5645 copier - Code sc546
We were given a Lanier 5645 copier for our church, it worked fine until we moved it when it was given to us. Now it gives us code sc546 and will not work. Can you please help us???
  • Lanier Expert
  • 1,326 Answers
Try this press the "yellow/ca" botton, then enter 1-0-7, then press and hold the "red" stop" till the display changes. Once, it changes turn the Main power switch OFF. Not the one on the control pannel. Let it power down then turn it back ON. If the problem is still there try to turn the copier Off again and unplug the sorter/ finisher and turn the copier back ON. Is the problem gone, if so you may have to get a service person come in and repair the sorter. Good Luck.....
Posted on Apr 06, 2009
SOURCE:
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Hoe do I empty the toner waste on an old Lanier 5645?
Its the brown belt thing on the right door, take off the 2 springs and remove the belt assy and empty, very messy...-Carl
Oct 16, 2014 | Lanier Office Equipment & Supplies
Service code SC546 on Model 5627
SC546 is universal in Ricoh, Lanier and Savin. It is indicating that the machine does not see the fuser.
Apr 26, 2011 | Lanier UNKNOWN
What is error code cs990 in lanier 5645
change the drum unit and initialize the ID sensor -thanks
Jan 05, 2011 | Lanier Office Equipment & Supplies
I have a Lanier 5635 and its not working. The error code is SC546. Ant ideas whats going on.
546 A Unstable fusing temperature The fusing temperature varies 50°C or more within 1 second twice continuously. • Thermistor defective(temp. senzors in the fixing unit) • Poor connection of the fusing unit • Power supply unit defective
Jun 23, 2010 | Gestetner DSm515pfd Digital Copier -...
I need to purchase a 802.11b Interface Card for Lanier 5645. Do you know where I can find one?
contact your local lanier dealer and tell them what you need. beware though the 5645 is a few years old, it may not be available
Oct 12, 2009 | Lanier Office Equipment & Supplies
Lanier 5645 has a sc542 error code
this is a problem with the thermistors and will need a technician to come out and fix it for you, the part #'s are aw100052 and aw100053 for the thermistors but you have to enter service mode to clear and reset the code.
if this answers your query please rate my answer accordingly
Regards
Sep 14, 2009 | Lanier Office Equipment & Supplies
Lanier copier ld145 locked up, code is sc546
Fuser warm up problem. Cause needs to be fixed and then code can be reset in service mode by a tech.
Jul 29, 2009 | Lanier Office Equipment & Supplies
We were given a lanier copier 5645 for our nonprofit. When we moved it - it won't work. It says the cover is open but its not...help! it won't copy
The switch that detects the open cover is probably broken or stuck. Do this. Lean / press on the cover while trying to copy. Does it work then? If it does, you know for sure that the switch is stuck. If it doesn't, the switch is broken.
How to find this switch? Is there a small plastic tab on the cover that goes into a hole that you can see? Those are usually where the switches for such covers are located. Spray some electronic parts cleaner down this hole (available at auto parts stores). See if this helps any.
Bilal Hassan
Clarksville, MD
Jun 11, 2009 | Lanier Office Equipment & Supplies
How can I find a schematic design of Lanier Model 5635/5645 Copie
Goto my website and Download the file from the Public Folder. It is the only Point 2 Point in the folder.
Do not forget to vote Yes or No if this information was helpful
www.copytech21.spaces.live.com
Apr 01, 2009 | Lanier Office Equipment & Supplies
1,312 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
gggg
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
