Question about Kenmore Elite 44173 30 in. Electric Cooktop
Burning plastic smell coming from new cooktop fan.
I just used my Kenmore Elite glass smooth cooktop for the first time. There is a smell of burning plastic coming from the fan underneath. Is this normal or should I stop using it and call for service?
    New Friend:
Sorry - this is not an answer but a question. Did you get your problem resolved. We just purchased a induction stove & oven and are having the same problem you described. Could you let me know what happened. Regards Bob
Posted on Mar 15, 2010
SOURCE:
My Kenmore propane fueled gas oven gives off a powerful strong smell every time it is started. The burners on top do not. Is there any way I can correct this?
this is because the gas is on full before the oven lights
IT is an explosive situation and should be quickly corrected by an accredited gas fitter
the soot indicates an incorrect burn ratio and that will be the major part of the problem
Jan 08, 2016 | Kenmore Elite 30" Stainless Steel...
How to clean glass cooktop on Kenmore electric range
Razor blade paint scraper at 45 degree angle, then use non-metallic dish scrubber with stove top cleaning product.
Jun 06, 2014 | Kenmore Elite 44173 30 in. Electric...
Jenn-Air Cooktop JED8430BDS
That is an obvious burned wire, or burned thermal cutoff etc
Nov 09, 2013 | Jenn-Air JGD8130 Gas Cooktop
There is a plastic burning smell coming from my LG range, both when using the oven and the stove top
check the vent at the back something may have fell into the breather. something like a plastic seal off some food.
Oct 27, 2013 | Cooktops
Burning smell from LG oven
Hi Mike Plante, I read your problem and would be very appreciative if you can share the solution that you eventually found, as my LG unit has experienced this exact problem after the same repairs were made. Please post an additional comment on the website. Thanks, Jeff
Mar 27, 2013 | LG Ranges LRE30453ST 30 Inch Freestanding...
Kitchenaid 36" glass cooktop with small crack
A small crack, turns into a big crack, Short of ordering a new piece of glass, there is no "fix" sorry. YOu can continue to use it, but eventually it will run across the cook top, and then shatter the glass... Better be safe than sorry.
Jul 31, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Stove not on - but fan comes on automatically -
it sounds as if the thermostat is broke. it could be the two wires off the thermostat are after melting together. ( burning smell). the thermostat stops power going to fan when it sences below a certain degrees. but your one has been cut out of the circuit due to the two cables melting together. this means fan will constantly stay on. you need to find and replace thermostat and make sure no cables melted together. if they are then seperate and use insulating tape to re insulate.make sure circuit breaker is off while doind this
Jan 16, 2009 | Jenn-Air JED8230 Electric Cooktop
JED8430 Fan Burning
great love it when people do this just commom sense most of the time
Dec 28, 2007 | Jenn-Air JED8430 Electric Cooktop
Kenmore Elite 44173 30 in. Electric Cooktop Logo
736 people viewed this question
Top Kenmore Cooktops Experts
jdthefixer
mcgsp
Level 1 Expert
k24674
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
