Epson TM-U220PD Matrix Printer Logo
A
Anonymous Posted on Aug 12, 2013
I have installed APD_455aeWM but still cannot detect printer Windows Xp
2helpful
Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
2helpful
Driver not support
remove all epson drivers.
download the following one APD-406aE and install
run as it will try and setup. if driver does not install go to driver and click on usb or xp one it will go further and install and work do test print.
1helpful
2answers
Want to install printer
If you are running Windows XP or Windows Vista, you may simply plug in the printer to the computer, and the computer will install the generic driver.
By default, Windows XP and Vista already has the generic driver installed.
However, if the printer is not a Plug-n-Play device, you will need to load the CD that came with the printer, and follow the installation wizard.
Thank you and good luck!
2answers
Driver will not install photosmart 7760 on windows
You can go to hp.com/support there by typing in your product 7760 photosmart be given a list of software to download with the xp os. That software should install your printer.
Hard drive failure required rebuild of XP Home on Dell computer. XP Home updated to SP3. Canon Multiplass F80 printer will not now work. I downloaded latest XP drivers from Canon web site, but installation...
I found that some Windows Plug and Play services were note running and were set to start 'manually'. I started those services which seemed related to Plug and Play, and the installation went without further errors.
I HAVE PROBLEM IN INSTALLING SOFTWARE
u have chak ur usb cable has been damged or not working take new usb cable & connect it reinstall driver
13helpful
4answers
Problem setting up TM-U220
print the self-test, push the feed botton while powering on...
you can see there the serial interface...
baud rate, data bits, parity, stop bit etc...
then go to the printer and faxes,
right click the epson driver and click properties...
go to the ports window...
click on the epson tm u220 reciept.
click configure port...
adjust the baud rate as same as in the self test...
it works...
1helpful
3answers
Canon Multipass c20 driver for XP
MULTIPASS C20/C50 ON WINDOWS 2000/XP This device is not compatible with Windows 2000 and Windows XP as a multifunctional device. For this product, Canon advertises compatibility with the following operating systems: Windows 95, 98, Millennium Edition (Windows ME).
Printing functionality may be possible by following the steps below.
Step 1 – Install a compatible printer driver.
1. Start the ‘Add Printer Wizard’ from the Printers folder (Windows 2000) or the Printers and Faxes folder (Windows XP).
2. Ensure that the ‘Automatically detect my plug and play printer’ tick-box is not ticked. Press next.
3. When prompted, ensure the printer port is selected on to LPT1. Press Next
4. When the list of manufacturers and models is displayed, click on Canon, and then BJC4200. Press next until the installation is completed.
5. The printer driver should now be installed.
If you are using the BC22e photo cartridge, you will need to download the BJC4200 driver from the www.canon.com.au website.
Step 2 – Setting the Multipass machine to Printer Mode.
1. On the Multipass keypad, press Function, followed by 0.
2. Press the left arrow key until you see Dos Printing.
3. Press Start twice.
If you have successfully completed the above instructions, you may now find that you are able to print to the Multipass machine. To restore the Multipass back to its original mode, press Function, and then Printer Reset.
2answers
Need printer driver
Please download APD 3.04 from the epsonexpert website. When installing the driver it will ask you on what operating system you are going to use. Please select windows 2000 instead of xp. You should be good. If not use generic text (if you are using parallel or serial cable).
8helpful
4answers
Epson TM-U220 Matrix Printer not printing in WinXPP
hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
