In order to set-up a wireless IP security camera to broadcast on the internet, instructions ask to set-up my router(2wire 2701hg-t) to perform port forwarding. How do I do this?
Access your gateway homepage by opening your internet browser and typing this on the address bar: 192.168.1.254/management. then key in your system password and click on Settings under Firewall. there's option#2 (allow individual applications), click on "Add a new-user defined application", input the data and click submit another way is to enable DMZ plus mode. that option would actually make all the ports open. use this if option#2 is not working. after making the above changes refresh your router, just unplug then replug it from the power.
Try the link below it may do it for you if your router is supported on the site http://www.portforward.com/
I dont think the port forward is the problem its the saftey feture built in to the firewall in advance options
I am using Vista the set up on www.portforward.com isn't the same and it didn't work for me.
Maclin
how do i forward
I have a exactly the same router. The cam opens fine from the cam to comupter,but the router won't let the internet in to see the cam. on default port 80 it's worked only. openned firewall attack settings, applied special application ports for the device, tried different ports 80, 81, 88.Need help, kimbo
Same problem on Qwest 2-Wire 2701 HG-D
