RIM BlackBerry  Pearl  8100 Logo
A
Anonymous Posted on Aug 12, 2013
I have a blackberry torch 9810 it says reload software 513
5 Related Answers
Anonymous
  • 173 Answers
  • Posted on Mar 12, 2009
SOURCE: my blackberry has n error jvm or jum 513
Thats a password error. Basically you need to reinstall the phones software. You can do this from the Blackberry desktop menu. You also need to first download your corresponding phones software and install it on your computer. This should take care of this problem.
However sometimes that doesn't solve the problem. If so, then try the flash without the battery in the phone. The flash will fail the 1st time around and then gives you a different code. Then flash it again with the battery and it should be al fine.
Anonymous
  • 407 Answers
  • Posted on Jun 02, 2009
SOURCE: blackberry pearl
Try holding these keys simultaneoulsy.
ALT+RIGHT SHIFT(CAP)+DELETE Until you get a blank screen then power on.
Failing that power off, remove your battery for 30 seconds and then power on.
NovaHorizon
  • 7 Answers
  • Posted on Jun 05, 2009
SOURCE: need to reload software 513 blackberry
the Application error 513, reset message says that the device OS is toasted and needs to be rebuilt. In order to do this, you need to have Blackberry Desktop manager on your computer, your data cable, and a download for your device software. Either from blackberry or your carrier. The easiest method is to download and install the device software. Once it's installed, launch desktop manager and plug in the phone. If the phone is detected, you will be prompted to update. Follow the prompts. If not, you will have to do it the hard way. open command prompt (start>run>cmd) and goto C:\program files\common files\Research in Motion\Apploader Then choose Loader /NOJVM That's going to rebuild the blackberry.
Anonymous
  • 10 Answers
  • Posted on Jul 13, 2009
SOURCE: how do i reload software 513 for my blackberry storm.
What you need to try to do is reinstall the blackberry OS (operating system) on your device.
Assuming you have verizon
First install Blackberry desktop manager it should be in the CD that came with the phone.
If you can't find it download it https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=5E695511C1F9656B8E3E63DAB060F469
Then download the OS software for your phone http://vzw.smithmicro.com/blackberry/download.aspx?ct=personal"
Install it
Connect your phone to your computer and start Desktop manager
Click on application loader, on update software click start, click ok on USB pin selection.
when you get to the device backup and restore options, click settings and make sure backup options box is unchecked and device data boxes are both checked, click ok, click next, skip the email signup stuffs,and finish.
After the software is installed the phone should boot back up
Anonymous
  • 541 Answers
  • Posted on Aug 10, 2009
SOURCE: reload software 513 error
After typing an incorrect password ten times and restarting the BlackBerry smartphone, the following error appears:JVM 513
All of the data and applications on the BlackBerry smartphone have been deleted and The BlackBerry® Device Software must be reloaded on to the BlackBerry smartphone (Due to the Java Virtual Machine (JVM) error, the BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to reload the BlackBerry Device Software using the Application Loader)
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 and 4.6, perform the following steps:
1) Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
2) Double-click Application Loader.
3) Click Add/Remove Applications.
4) Type your BlackBerry smartphone password and click OK.
5) Select the check boxes next to the names of the applications you want to load.
6) Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
7) Click OK.
8) Click Next > Finish
9) When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager.
My blackberry torch 9810 gives me the error code 507 at start up
I think this is a usual thing by that thing. It will clear on next days.
1helpful
It says Reload Software: 513
After the maximum number of password entry attempts is exceeded by supplying incorrect passwords, and the BlackBerry smartphone is restarted, the following error appears:
Steps how to reload can be seen in below website
http://www.blackberry.com/btsc/search.do?cmd=displayKC&docType=kc&externalId=KB11320
Thank You
45helpful
3answers
Reload software : 513 comes with my blackberry 8520 curve what can i do
i'd attempted 10 times USB pwd, and now my phone s/w was all whipped off. msg on screen is reload software 513, plz help. i'd just got my Curve 8520 3 days ago...
4helpful
My blackberry keeps saying download software 513
my blackberry says reload software 513 what site can i go on to fix my phone
105helpful
9answers
Need to reload software 513 blackberry
Top RIM Computers & Internet Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Alexander
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
